About the 307s steering pump
08.05.2020 21:14 # 1
mt.yazar
Good for everyone, friends, I wanted to convey to you a situation I had recently.
My car 307 1.6 xr, the buzzing sound at the steering wheel increased and there was hardening. My hand is slightly prone, I disassembled the steering pump, cleaned it and cleaned the inside of it.
I cleaned it, picked up the steering wheel and fitted it, but there was a problem. I wasn't supposed to put the same oil. Since I was in Balıkesir, I could not find the original oil (also in total fluide) and I put the total fluid atf oil on the recommendation of the master at the service.
However, after I put this oil, the whine has increased, I have seen in my research that the viscosities of these oils are very different. I bought and changed the steering oil in the original total fluide from the internet, and now the whirlwind in the steering wheel has been reduced unnoticeably. I also heard that the main cause of steering stiffening is from shock absorber and shock absorber balls.
First of all, my friends who hear the steering sound should replace the steering oil with original oil.
08.05.2020 21:14 # 2
iso0625
I do not understand those masters already, he says "put atf" in front of him. If you do not know my brother, I do not know, then there is an expense to the nation. I do not know if our Peutos (I have 407) should say such a restriction in steering oil, but there is a Total Fluide DA incident and there is no alternative. I don't think it's a problem that I will change anytime soon, but I think that the same oil has lost its properties for 10 years. Was there any softening after the change at the wheel or a change other than sound?
08.05.2020 21:14 # 3
mt.yazar
There has been some softening right now, but of course the hydraulics of our vehicles have a little hard character, of course, to get the softening fully, the shock absorber shock absorber balls must be overhauled or so who knows when it has changed.
08.05.2020 21:14 # 4
x571
[QUOTE = mt.writer] There has been some softening right now, but of course the hydraulics of our vehicles have to be overhauled to absorb the shock absorber balls wedges or something to complete the softening of the character. [/ QUOTE]
Don't worry, it won't soften. 4 Shock absorber replaced with bearing and chock, no softening. The biggest softening happened when I replaced the tire. I think our goods are like this. They are not the type to change with little finger. Like the Bedford steering.
