About the 307 oil filter;
08.05.2020 17:31 # 1
sercan1903
Hello friends;
There was no warning before the oil change in my 307 1.6 HDI vehicle. However, after changing the oil, the engine started to give a low oil pressure low warning after the engine warmed up. The problem may be caused by it. Is it related to the oil filter? Can friends with knowledge help?
08.05.2020 17:31 # 2
Serkan
If the oil filter is not original, he can do it. Friends have received the same warning before because of the supplier industry filter.
08.05.2020 17:31 # 3
sercan1903
Thank you very much, probably not original. So when I replace it with the original, will it be improved? or do I need to take any additional action?
08.05.2020 17:31 # 4
Serkan
I can't say for sure, but there are those who changed it before
08.05.2020 17:31 # 5
ismailkaya
Do not forget to change the gasket after changing the oil filter, otherwise oil may leak from the cover through pressure.
08.05.2020 17:31 # 6
sahin-peugeot
The filter is either in the sub-industry or there may be a small oring at the end of the filter, they may not have attached it, the filter gasket must be replaced, and the gasket is already coming out of the box.
08.05.2020 17:31 # 7
djchaos
definitely use original parts in your vehicles.
