About the 307 high beam system;
08.05.2020 17:20 # 1
sercan1903
Hello friends, I am waiting for your help about the problem of the main beam system I encountered in my 2005 307 XT vehicle. Can friends with knowledge and experience help?
08.05.2020 17:20 # 2
Alicilik
BSi is likely.
08.05.2020 17:20 # 3
ondercan
hello.
most likely it could be from the engine fuse box because the role of the high beam is in it.When you are still stuck again, hit the edges of the engine fuse box with a pliers and a screwdriver so that it may go out.
08.05.2020 17:20 # 4
SurungeN
slm dude far rolen stays on and you are experiencing this problem from me, did i get the magnetism & nbsp; from working continuously, i would recommend you to change the contacts of the role & nbsp;
08.05.2020 17:20 # 5
xmen
I wonder if anyone has encountered this problem and found a solution.
08.05.2020 17:20 # 6
xmen
[QUOTE = xmen] I wonder if anyone has encountered this problem and found a solution .. [/ QUOTE] & nbsp;
current
08.05.2020 17:20 # 7
Alicilik
Engine fuse box will change ...
08.05.2020 17:20 # 8
xmen
[QUOTE = Buyer] The engine fuse box will change ... [/ QUOTE]
Ali, this relay is not possible to change, whether the box is not so cheap :)
08.05.2020 17:20 # 9
Alicilik
Role integrated role. A good master needs to change.
08.05.2020 17:20 # 10
sanctuary35
I have the same problem with me, they said that com2000 needs to change. Com2000 from 1400 lira bnm chassis no:
