About Shock Absorber and Spring.
08.05.2020 16:20 # 1
Selo
Greetings. & nbsp;
2006 model X-Design 206 user. I will make some changes in my vehicle and I have two options.
1st option: & nbsp; 16 '' steel rim, 5Cm sports spring to the front and front-rear sports shock absorber. 2. Option 2: & nbsp; 16 '' steel rim, 3.5Cm sports spring to the front.
Products 206Quick will be out.
How do you think my car will be more comfortable? Which one should I have? I attach importance to comfort as much as the image. I do not want the vehicle to hit the ceiling in bumps and hit my head on the ceiling.
08.05.2020 16:20 # 2
muzaffer
Brother, I did it by cutting prginal augers in my vehicle. Indeed, the thing is that it does not matter whether you have a shortcut or a spring, except for the original auger and shock absorber. & Nbsp; If you make a transaction, you will learn how to cross the bumps in the comfort of this car and to memorize the places of the pits, that is, the folding account of the rose-loving thorn.
08.05.2020 16:20 # 3
Selo
It was dangerous to cut the originals, and in the long run, it was also very harmful to the car. "Ouch"
08.05.2020 16:20 # 4
selo is definitely option 2. my skin is never even thinking ... & nbsp;
08.05.2020 16:20 # 5
Selo
Why am I bro?
08.05.2020 16:20 # 6
I have 306 .. I bought a 3.5cm eibach pro kit and I am very pleased .. spring quality is very important here ...
why if you say
1. If the vehicle falls by 3.5 cm, there will remain a stretch. You will not hear the cuddly sound in the bumps. You will not compromise on comfort.
2. if 5 cm falls, the vehicle will look visually perfect .. your yawn will be reduced and the shock absorbers will be loaded too much ... comfort will be almost 0 .. sounds will enter the vehicle inside ...
3. shortly if you say comfort there is 3.5 no visuals If you say 5 cm ..
: //www.google.com.tr/url? sa = t & amp; RCT = j & amp; q = PROKIT% 20eibach & amp; source = web & amp; cd = 10 & amp; ved = 0cfsqfjaj & amp; url = http% 3A% 2F% I 2fwww.modifiye .com% 2Fforum% 2Ff53% 2Feibach-prokit-arc-where-can I find-33422% 2F & amp; ei = yzW8Tu-iFdDt-gaStr3wBw & amp; usg = AFQjCNHJlOOhtZzH8zcGET17mggTeYasja "=" " a> < br> by_ersin 2011-11-10 22:42:41
08.05.2020 16:20 # 7
Selo
I understand teacher. So how about the shock absorber? Do you think the sports shock absorber has the advantage or not or not?
08.05.2020 16:20 # 8
muzaffer
[QUOTE = Selo] It was very dangerous to cut the originals, and in the long run, it was very harmful to the car. "Ouch" [/ QUOTE ]
It's been a year and I'm still running. Let's look. Reviews
