About Peugeot 307 1.4 XR?
08.05.2020 18:02 # 1
C.Kaan
Peugeot 2005 307 1.4 I Need Information About This Model With XR LPG What Does It Burn In LPG - What Does It Burn In Gasoline - What Does It Burn When I Turn On The Air Conditioner? Does the motor lift the case?
I am waiting for your comments.
C.Kaan 2013-11-04 23:35:57
08.05.2020 18:02 # 2
hsnsnl
307 1.4 gasoline can not be passed on, my teacher.
08.05.2020 18:02 # 3
ismailkaya
307 2005 model & nbsp; & nbsp; 1.4 90HP & nbsp; black steel cant & nbsp; I have a vehicle & nbsp; I do not have gasoline lpg. I have been using it for 3 years. & nbsp; & nbsp; 100 km. & nbsp; 5.5 consumes between 6.5 & nbsp; I use it in mountainous terrain & nbsp; you & nbsp; & nbsp; I am very satisfied I bought at 30,000 and now it is 93,000 & nbsp; I am thinking of using LPG for a long time or I will sell and have a wedding at the beginning of summer & nbsp;
08.05.2020 18:02 # 4
Aziz
I know that nobody likes the 1.4 petrol 307 and doesn't recommend it. I am saying I heard that I was never intimidated.
08.05.2020 18:02 # 5
C.Kaan
[QUOTE = hsnsnl] 307 1.4 gasoline will not infect, hod man .. I think you will have a lot of troubles with the tube .. 1.4 diesel will be bought but not 1.4 similar. >
What is the Reason? Today's Technology Small Engines Today Ford Focus Has A Vehicle Over 1.5 Ton But There Is 1.0 CC Engine, Clio IV Has Launched With 0.9 CC And 1.2 CC Engines And Despite That People Installed LPG On 0.9 - 1.2 Engine.
[QUOTE = ismailkaya]
307 2005 model & nbsp; & nbsp; 1.4 90HP & nbsp; black steel cant & nbsp; I have a vehicle & nbsp; I do not have gasoline lpg. I have been using it for 3 years. & nbsp; & nbsp; 100 km. & nbsp; 5.5 consumes between 6.5 & nbsp; I use it in mountainous terrain & nbsp; you & nbsp; & nbsp; I am very satisfied I bought at 30,000 and now it is 93,000 & nbsp; I want to have a lpg and use it for a long time, or I will sell it & nbsp; wedding at the beginning of summer [/ QUOTE]
The Model We Are Interested In Is Greatly Possible 1.4 8 Valve 75 HP Model In The Market Is Estimated That It Will Consume 8 Liters Of Fuel In The City In Gas Market, If This Is The Right One Value Because If We Calculate Gas From 5 Lira It Makes 0.40 Cents In Kilometers If We Use 10 Liter Fuel In LPG, It Will Burn 0.28 Cents Per Kilometer From 2.80 Cents Liters.
[QUOTE = Aziz] I know that nobody likes 1.4 307 gasoline or not. I'm saying I'm hearing I've never been intimate. [/ QUOTE]
Yes 1.4 Gasoline Why It Is Not Recommended, But We Do Not Expect 106 GTi - 172 RS Performance You Can Take The Person Who Will Take The Vehicle From The Vehicle. It Is Enough To Stay Behind The Trucks On The Enough Long Road. 1.4 Liter Actually Not That Small Engine As I said above 0.9 - 1.0 - 1.2 Engines Spread Quite On The Market.
Thanks For The Information, I'm Waiting For Your Comments.
08.05.2020 18:02 # 6
ismailkaya
I recommend vehicles with engine version 1.4 to 90 hp
08.05.2020 18:02 # 7
Aziz
[QUOTE=C.Kaan]
[QUOTE=Aziz]1.4 benzinli 307 yi kimse sevmiyor tavsiyede etmiyor diye biliyorum. ben duydugumu söylüyorum hiç içli dışlı olmadım.[/QUOTE]
Evet 1.4 Benzinli Niye İse Tavsiye Edilmiyor, Ama Biz 106 GTi - 172 RS Performansı Beklemiyoruz Araçtan Aracı Alacağımız Kişiyi Götürüp Getirsin Onun İçin Yeterli Uzun Yolda Kamyonların Arkasında Kalmayalım Yeter. 1.4 Litre Aslında o Kadar Küçük Bir Motor Değil Yukarıda Dediğim Gibi 0.9 - 1.0 - 1.2 Motorlar Piyasaya Oldukça Yayıldı.
Bilgilendirme İçin Teşekkürler, Yorumların Devamını Bekliyorum.
[/QUOTE]
Bizim demek istediğimiz performans değil tabiki, 70 hp olması :)
Yeni nesil motorlarla kıyaslamak yanlış olur, çünkü diğer degerler farklıdır.
1.0 yaris + 70 hp + 93nm tork + 995 kg + 0-100 km 15,3 sn
1.2 jetta + 105 hp + 175nm tork + 1302 kg + 0-100 km 10,9 sn
1.4 307 + 75 hp + 120nm tork +1142 kg+ 0-100 km 15,6 sn
Gibi, Jetta birazda farklı tabi ama örneklik bence :))
Aziz2013-11-05 14:27:10
08.05.2020 18:02 # 8
C.Kaan
8 Valter TU3 Engine Industrial But these models to Turkey has come, 16 valve with et3 Models in Turkey this Motor Vehicles With unsold Only 90 HP with 16 Valve Engines Sold She Heard a sensation 8-16 Valve Issues Important 8 Valve If No, But 16 Valves Are Warm Looking At The Vehicle.
08.05.2020 18:02 # 9
Aziz
16 valves 90 hp already :) I think you can look hot :)
08.05.2020 18:02 # 10
mcemin
[QUOTE = ismailkaya] I recommend vehicles with 1.4 90 hp engine version [/ QUOTE]
Hi;
As of today, I decided to buy a 2005 model 307 1.4 XR gasoline vehicle. Probably we will not sell on Monday. There is something I want to ask alone. It says 55KW in the license, which means about 75HB of power. The vehicle is said to have 16 Valves. According to the information I got from you, 16 valves should be 90 HB. Could it be misspelled to the license? Because I have come across many times that the power is written wrong. My car, which was 136 HB before, was incorrectly written as 160HB in the license change.
The former owner said that the 307 1.4 XR model car I mentioned was also 16 valves. How do we know or determine if an engine is 16 or 8 valves?
In the meantime, the vehicle I mentioned was unchanged, accident-free and original 94 thousand and we got a clean 19500TL.
I would appreciate if you help enlighten me.
08.05.2020 18:02 # 11
Barut
[QUOTE = mcemin] [QUOTE = ismailkaya] 1.4 I recommend vehicles with 90 hp engine version [/ QUOTE]
Hi;
[/ QUOTE] The vehicle's engine is 90 hp if it has a black cap. None, if it is gray without cover, it is 75 hp. Red dream 2014-08-24 15:53:24
08.05.2020 18:02 # 12
mcemin
Thank you very much for the information you provided. The vehicle engine is black and with a cover. It is already mentioned in the model name as 16V. It was misspelled as 55KW in the license. I bought the car, but it was constantly on my mind. I even did a dyno test in your friend's expertiz shop. I saw 88 HB as a result of the test ;-) I liked my new car more.
No license has been issued yet. As of yesterday, I had the compulsory insurance. It will probably be misspelled in the new license as 55KW. It should write 65KW but how do we change it I don't know the value from the license.
Thank you again.
08.05.2020 18:02 # 13
cavit cevo
When selling more than 1.6 xt, you will not have difficulty xr at least xs sports tekkap is the xt end.
Air conditioning on LPG in addition to 1.6 xt burns 0.25 kr
08.05.2020 18:02 # 14
emresensoy307
Friends, I have a 2006 model 307 1.4 16 90 horsepower arc, I am very happy with the vehicle, but before I bought the vehicle, I was praying to have a lpg, but after I started using the vehicle, I decided to give up this decision. Waiting for 6 performances, but after 2006, I would say take 16 valves90 horsepower I'm very happy
08.05.2020 18:02 # 15
mcemin
I am very happy with my 2005 model 1.4 petrol 307. A vehicle that has never seen an LPG. I also use gasoline. Performance and fuel consumption are ideal. No case does not pull heavy engine vs story. Of course it is not at 1.6 performance. But the 1.6 focus is as good as the food on departure. The end result is 90hp power. This is not 75, but friends, 90hp is the power of this engine. Your information.
