About Peugeot 206 + headlights
08.05.2020 19:50 # 1
hermanito
Hello friends, I have received 206+ vehicles until 15 days ago. I have a question about headlights. As you know, there are 3 headlights at the top and 1 fog lamp at the bottom. Only 1 of the 3 lights above are lit. If others are not burning, where do you get help? Thanks in advance
08.05.2020 19:50 # 2
Alicilik
Do you mean the taillights?
There are 3 bulbs.
Back lamp with white inside
Signal inside the white round on the edge
Parking / brake in red
The mists only burn the left side in the bumper at the bottom.
08.05.2020 19:50 # 3
hermanito
[QUOTE = Buyer] Do you mean the tail lights?
There are 3 bulbs.
Thank you for the answer. I mean the front. The fog lights on the bottom are on. Its ac cover is separate. I see 3 bulbs at the bottom. It shrinks inwards from the sides separately.
https://www.google.com.tr/search?q=peugeot+206+plus&biw=1366&bih=643&tbm=isch&source=lnms&sa=x&ved=0ahukewit-6n1wjnnahugwhokheuqdz0q_auıbigb#imgrc=rtpvdw2vun_g5m%3 to
08.05.2020 19:50 # 4
parking lamp + high beam + low beam respectively. When we opened the first stage, the parking lamp should burn out, if it does not burn it exploded. the second stage is shorter, they say it is burning, pull the lever to yourself as it is + 3. Meanwhile, welcome to us.
08.05.2020 19:50 # 5
Alicilik
The headlights have outermost signals.
H7 dipped beam inside with a bottomless small parking light.
On the inside, there is the H1 high beam bulb.
Parking lamps (small bulb below dipped beam) light up when you move the end of the turn signal lever to zero-I
When you bring it from I to II, low beams also come on together with the parking lamps.
If you knock and release the signal lever to yourself, you will make a selector, and the long-running bulbs light up at the time of pressing.
If the park or dipped beam is on and you pull the signal lever fully towards you, the high beam will be lit.
There is a rotating part in the middle part of the signal arm. If you turn it towards the dial, if there is a front fog lamp in the first level, the rear fog lamp will be lit. If you turn it again, the rear fog will be on. When you turn it in the opposite direction, it closes the rear fog first and then the front fog.
If you light up the high beam while the fog is on, the fog will go out. When it turns off the long beam, it lights up.
If you pull the key and make a selector after stopping the vehicle, the headlights will stay on for 50 seconds.
08.05.2020 19:50 # 6
hermanito
@ Appealing @ thank you very much for the sonerkyl answers, thank you very much
