About Peugeot 206 Fog Light Construction
Homepage » PEUGEOT MODIFIED PLATFORM » How To
08.05.2020 19:21 # 1
samet206
Friends, I will install fog lights on my vehicle, the bumper is painted tomorrow, everything will be ready to be installed. ? I'm waiting for urgent help ...
samet206 2015-07-08 22:05:33
08.05.2020 19:21 # 2
samet206
Current ...
08.05.2020 19:21 # 3
madblueblacksea
You have to disassemble the hoods or try to lay it under the vehicle and attach it. If there is no installation in the vehicle, it will not be able to use the original sockets in the fog and will be connected directly to the bulb with f plug. You need to insulate well takes water takes steam makes it rot early
08.05.2020 19:21 # 4
samet206
[QUOTE = madblueblacksea] You have to remove the hoods or try to lie under the vehicle and connect it. If there is no installation in the vehicle, it will not be able to use the original sockets in the fog and will be connected directly to the bulb with f plug. You need to insulate well takes water takes steam makes it rot early [/ QUOTE]
First of all, thank you Master, if you look at the subject, you have done these operations as well :) I thought we would do something like a socket style. It is similar to the original but I don't know how it would be. Also, the bumper will be fitted with bodywork fog. Even if we go to bed, he can push, but now I have to put the bumper as a logic, we will pull the cables by working somehow ... There are those problems about insulation.
08.05.2020 19:21 # 5
madblueblacksea
I did not make mine original fog :) But for two years, I can say that there is no hole in the car that I have not inserted my finger. I installed the torpedo lamp last week. I made led lighting for the baggage, I put the lamp of the trunk into the torpedo and made it up like a peanut. I thought long ago, but when I disassembled the tape recently, the installation of the idle torpedo lighting triggered me. I dealt with electronics business, I did motorcycling in the industry, let's say that the accumulation of years is triggering the person and you are alive everywhere :)
Anyway, let's come to your subject, enough advertising Big smile If you get the bumper installed and there is a bottom case, it remains to remove the hoods to reach the fog. If you can, the cable solder to the original socket is the healthiest. You will not only spoil the insulation with the back cover, but also connect the installation to the fog more easily.
08.05.2020 19:21 # 6
Alicilik
Original installation can be done, let me tell you about the horse number and what to do.
08.05.2020 19:21 # 7
madblueblacksea
[QUOTE = Buyership] Original installation can be done, let me tell you the specially discard the number of the sema and what to do [/ QUOTE]
Can you tell the way of the schemes
08.05.2020 19:21 # 8
samet206
We installed the bumper, I will do the electrical installation tomorrow, I found a socket similar to the socket of the fog, I will finish with the socket in the electrician.
Thanks to your arm, I will handle it with a thank you button for your attention.
08.05.2020 19:21 # 9
lodos41
I want to add fog lights, can you send me the necessary parts and documents to me? I also like the GTI front bumper. my car 2001 colorline. lodos41 2015-07-05 02:44:57
08.05.2020 19:21 # 10
madblueblacksea
[QUOTE = samet206] We installed the bumper, I will do the electrical installation tomorrow, I found a socket similar to the socket of the sisters, I will finish the electrical system with the socket, the only thing that bothered me was the openings left.
How clear? The fog left behind the bumper
08.05.2020 19:21 # 11
samet206
Exactly, the fog was left behind the bumper, we had a problem with the long-lasting products in the sub-industry products, we sat down with very little differences, but the color difference occurred in the paint of my bumper, so I canceled the project and put the parts on sale. I can do the operation.
08.05.2020 19:21 # 12
samet206
[QUOTE = lodos41] I want to add fog lights, can you send me the necessary parts and documents? I also like the GTI front bumper. my car 2001 colorline. [/ QUOTE]
Fits my teacher. I sell my GTI bumper if you wish. bumper, fog lights and grille. Also the hoods are not seated. We also stretched it with a steel wire and seated it. There is no other number.
08.05.2020 19:21 # 13
madblueblacksea
[QUOTE = samet206] Exactly, the fog was left behind the bumper after a long problem with the sub-industry products, we sat down with a little difference, the gap was removed, but the color difference occurred in the paint of my bumper, so I canceled the project and put the parts on sale, but I pulled the electrical installation, but if I sell the products, maybe the original fog I can get the headlights and cut my own bumper.
Two models of fog, my teacher came to me when changing one of the fog. The feet of the fog that I bought came together, but it was left behind. I said I went to the tracker, this is the situation ... He gave the one with short feet, so he sat down. It was a warehouse brand in two variants
08.05.2020 19:21 # 14
lodos41
[QUOTE = samet206] [QUOTE = lodos41] I want to add fog lights, can you send me the necessary parts and documents? I also like the GTI front bumper. my car 2001 colorline. [/ QUOTE]
If you have, please send the attached picture and the price of the bumper to a special msg.
08.05.2020 19:21 # 15
samet206
In order not to distract the issue here, let me write from a special point, there is already a lot of detail about the buffer mentioned in another subject.
08.05.2020 19:21 # 16
samet206
[QUOTE = madblueblacksea] [QUOTE = samet206] Exactly, the fog was left behind the bumper, we had a problem in the sub-industry products, we had a long effort and the gap was removed with very little differences, but the color difference occurred in the paint of my bumper, so I canceled the project and put the parts on sale, however, I pulled the electrical installation, but it was not worth it. If I sell the products, maybe I can get the original fog lights and cut my own bumper.
Exactly, the master did not sit back, we got a set in the full slot, the feet did not fit shortly, we took another set of feet, this time the fog was left, whatever we did was made clear, it worked out in the end. Although it is not understood, the fender dark bumper light color on the side of the vehicle is not completely different with the wrong time or paste polish. Unfortunately. I put it on his eyes, I work with LEDs during the day, I pulled the electrical wiring, because it looks like it was empty :) I became a master maduru again, I could not remove everything. GTI bumper enjoyed once. It wraps me but I don't know anymore.
08.05.2020 19:21 # 17
madblueblacksea
If he fails to achieve his color, paint it again, why are you a victim? What crime do you have if you did not take the paint in your bumper and went to the man and said that?
08.05.2020 19:21 # 18
Alicilik
[QUOTE = madblueblacksea] [QUOTE = Buyership] Original installation can be made, let me tell you about the discard number and what to do [/ QUOTE]
I don't understand what you mean?
08.05.2020 19:21 # 19
samet206
[QUOTE = madblueblacksea] If she couldn't match her color, paint it again, why would you be a victim. What crime do you have if you did not take the paint in your bumper and went to the man and said that with this [/ QUOTE]
The issue of paint has already created a problem that has not been brought to me, it sent me to someone who prepared the paint with a computer, I went to the place where he said, I had doubts about it, I had no doubts, he said that he would not hold the paint according to his preparation, but I said it would not be a bad thought, I made it ready for the painters. long story. Obviously in summary.
