About Peugeot 206 CC Manual Sunroof
08.05.2022 15:51 # 1
xairosk
Hi, I'm new to your forum and I'm so glad I found it. I'll stay in touch here for help and issues if I can.
br style="color: rgb102, 102, 102; font-family: tahoma; font-size: 14px; : rgb250, 250, 250;">I bought a 206 CC Convertible 1.6 last year, but its problems never went away.
Previously, the automatic roof was working, but when the window button in the middle failed and it came out one-to-one It stopped working after replacing it with
I know it works synchronously, so when a button breaks, the convertible doesn't trigger. I think it's a button related issue.
When I press the convertible power button and look at the system screen, it gives a Backdoor open warning (Every time I press it)
I am aware that it is a very simple electrical problem, but you know, the masters say high prices when even the simplest mistake does not work for them. Since I do not understand a lot of cars, this price goes up 2-3 times.
I tried to open it manually (I turned the locks, I turned the pressure sensor to the left and unlocked it) but when I lift it halfway, it seems like something is blocking it.
I want to ask you guys;
1. If I turn it on manually, will the electrical or convertible suspension parts deteriorate or be damaged over time?
2. (If I don't damage it) How can I get over the "forced halfway through" situation I mentioned above to open manually?
3. Is there a "proper" company on the European side of Istanbul that can solve an electrical problem ?
Really, this heat is not taken anymore and my air conditioner does not work at all (No freyon, air conditioner magnet and motor is broken, etc.)
For the sake of Allah, please help.I've been facing this problem for 5 months, but neither the internet nor the electricians could find the source of the problem.
Thank you guys in advance.
09.05.2022 08:54 # 2
It has to be opened manually. There is probably a problem somewhere. There are switches in many places in the ceiling, if one or more of them are broken, it will break due to it. There is no problem with manual opening. Although it is difficult to find a proper master, they want a lot of money for parts prices. My friend had the 307 convertible brought from abroad and repaired it himself just for this reason. The button you attached may not be compatible with the vehicle, have you looked at the chassis number and the part code
09.05.2022 09:27 # 3
xairosk
Hello Soner, thank you very much for your answer, yes, they sell very expensive parts, especially I do not want to go near the two-wire pull-out, but here is the case because of the necessity. I provided the original pop-up glass button for 600 lira, but I think the cables going to the switch are also a contact failure. There is also a displacement situation and therefore the convertible button does not allow to open because it cannot detect this situation. I could not look at the chassis number, it is very difficult to find from this button. I researched for a week, but the window switch I bought was exactly the same car (including model, year and engine). For example, I bought a Peugeot 206 window button, the Switch fit, but as soon as I pressed the button, the windows would go down and close completely. I realized that it didn't fit when I opened it and looked inside. By the way, I do the same operations as in the video you sent, but as I said, it gets stuck somewhere in the middle when I lift it up. I'll check it out today, at least I'll try to open it manually. Thank you very much for your reply.
09.05.2022 13:43 # 4
You're welcome. your part nose bro.
in addition to https://partsouq.com/ you can access the part codes compatible with your vehicle by entering the chassis of the vehicle from this site.
09.05.2022 13:48 # 5
xairosk
Yes sir but this is for 206. The bottom plastic of the CC glass buttons is turning brown. Its internal circuits are very different, but its external and socket part is completely compatible.
I'm fiddling with it, let's see if I can get a result, insha'Allah.
