About Peugeopt 206 Fog Light Process and Brands
Homepage » PEUGEOT MODIFIED PLATFORM » How To
08.05.2020 19:20 # 1
samet206
Hello friends, I have attempted to make fog lights on my 206 vehicles without fog lights.
I searched for a priority warehouse brand as a fog lamp, but I couldn't find it anywhere. All the parts are selling GVA Brand. There is no other option. I said I would buy the original valeo, they said 140 TL. I would buy GVA in an unwanted and unwanted way. I came from the warehouse, I bought it, I came home because there is no problem. I couldn't use it as one of the fog lights will change as there is a difference between the two products of the LUVI and the GVA. Now, my friends, I examined the GVA brand. The difference in the part is that there is a head in GVA, the bulb in plastic LUVI appears directly from the outside. When I look from the outside, which one should I do when I change it?
This is GVA Brand
Buddha LUVI Brand Who Do You Think?
08.05.2020 19:20 # 2
madblueblacksea
The original one has a hat, as in normal headlights. I know that this hat helps to distribute the light evenly, not to a single point.
08.05.2020 19:20 # 3
seamad
Hello, I made it with the original fog, but why do you think the inside of the fog may be constantly steaming?
08.05.2020 19:20 # 4
madblueblacksea
[QUOTE = seamad] Hello, I did it with the original fog, but why do you think the inside of the fog may be constantly steaming?
It gets air from the barrier. Check the most likely location back cover bi
08.05.2020 19:20 # 5
samet206
The master has a round lid on the back, which makes steam from there, it can be cut with a utility knife if necessary, and it can be used as a thin silicone.
08.05.2020 19:20 # 6
samet206
The original one has a hat, just as I said, but as you said, but how it is about giving light, I consulted for it, the light bulb without a hat gives me bad light. publicly.
08.05.2020 19:20 # 7
madblueblacksea
If both of them give you an electric power and you can see the result live, you can give us an idea.
08.05.2020 19:20 # 8
samet206
Smile I don't have the opportunity now but it looks like it will be because it was originally because it was capped, I read a topic that tells me what's the difference between the two and the fog of 206 in the other forum yesterday. Let's make a decision according to him.
08.05.2020 19:20 # 9
madblueblacksea
Don't forget to check the warm-up conditions when you connect the two. If the light without a hat is reflected directly on the windshield, it feels like it will overheat if it does not put a low wattage bulb
08.05.2020 19:20 # 10
samet206
Warm-up condition was tried in both of them, my normal teacher was tried, the fog changed, we were working healthy, we both preferred the model we liked, but I guess we canceled the fog because the project had problems in the bumper.
