ABOUT PERFORMANCE
08.05.2020 15:22 # 1
gist
Hi ,
2004 1.6 16 valve 60.I have 206 quiksilver.
The vehicle speeds 100 km in 5 thousand and 3 thousand cycles.
Is this normal value for this tool when you leak ??
Shouldn't the performance be much better?
thanks
08.05.2020 15:22 # 2
goktug
As you said, it should be much better. It makes 110 in 4th gear.
08.05.2020 15:22 # 3
xdesign
A good concealer fits him to 130 in 3bin with a nice valve.
08.05.2020 15:22 # 4
GokhaN
5 gears are normal around 100 110 at 3000 rpm
08.05.2020 15:22 # 5
tigerland
walla i have gti 100-110 I think your normal vehicle. tigerland 2011-05-02 16:06:59
08.05.2020 15:22 # 6
[QUOTE = xdesign] A good concealer puts him at 130 in 3 thousand with a nice valve setting (dot)
my beautiful brother you still could not learn the water is so hot :)) and you are doing it with so many modifiers. Sırıtma you are really breaking me Göz Kırpma
do you think the ratios of motor power and face are related? the face makes my motor power or are they excited?
In response to my friend who asked the question = handover and smiley relations are related to the gear ratios in the gearbox. It is normal for the vehicle between 100-110 as it is said in other friends at 3000 rpm in the 5th gear.
In my 1.8 car, the 5th gear is ticking 107-108 with 3000 cycles.
the cecol 2011-05-02 16:23:49
08.05.2020 15:22 # 7
my 307 3000 rpm at straight road 105 km / speed
08.05.2020 15:22 # 8
[QUOTE = ose307] my 307 straight road at 3000 rpm 105 km / speed [/ QUOTE]
this is exactly my brother :)) 206 2.0 gti 138bg machine with 105 cycles with 3000 cycles ...
Maybe 1.6 16v 110bg machine, I can not keep the gearboxes the same.
But even if the engine is 500 hp, the 5th gear will make 105 again at 3000 rpm. Sırıtma
consequently, the gear faces of the vehicle do not change as long as the gear ratios in the gearbox do not change.
08.05.2020 15:22 # 9
[QUOTE = cecol of]
As a small plus, it also depends on the final gear ratio and tire size. So basically 3 things:
1. Tire size
2. Gearbox gear ratios
3. Final gear ratio
08.05.2020 15:22 # 10
[QUOTE = koliva] [QUOTE = CeCoLi]
1. Tire size
3. Final gear ratio
One minute, my brother, if you want, put on 2 times bigger tire, the same face of the vehicle's face indicator.
Where does the km sensor stand ??? At the top of the transmission ... if you change the wheel cap from that pain, the indicator does not change. but your real face is changing.
I wrote the gear ratios, don't you see my brother anyway? Sırıtma last gear and gear gear etc. I said gear rates in general, yaaa :))
08.05.2020 15:22 # 11
xdesign
Cecoli really love you, but you understand from the car. I ask you how many times have you had a valve set in your life? The man's car sees 100 at 3000rpm at 5 is already normal for his stock. I am very curious if you can say that if I made it 130 in 3000 with the same gearbox, you still haven't learned :) Don't do it bro. As soon as I know that I do not know anything, I will forward my apology letter to you via admin :)
My friend who opened the title has no problem, it is normal.
08.05.2020 15:22 # 12
metin
Your transmission started to miss little by little.
my automatic 4 gear. 4th gear is 90 km / h at 2500 rpm and 110 km / h at 3000 rpm on straight road.
08.05.2020 15:22 # 13
[QUOTE = cecol of]
Since he said that the first message says that he is driving at a speed of 100 km, I perceived it as if the vehicle is going at that speed. So I said it depends on the dimensions of the wheel. If he says on the screen in terms of the value he reads, it is as if he is, of course, independent of the dimensions of the wheels.
For the second, it was officially word game. When the transmission says gear ratio, it does not include the final gear ratio. The two are different things, but you said the gear ratios in the transmission are different. Göz Kırpma
Koliva 2011-05-02 17:20:42
08.05.2020 15:22 # 14
[QUOTE = text] [QUOTE = ose307] straight road 105 km / speed at my 307 3000 rpm [/ QUOTE]
text brother is normal between 100 and 110 at 3000 rpm, it changes according to the road you go
08.05.2020 15:22 # 15
Muhammet CAKIR
I think the normal speed is because when calculating the gear ranges of the vehicles, 3000 revolutions are taken as basis, there is a little bit of play.
08.05.2020 15:22 # 16
106_arts
I have the same vehicle in me 1.6 16v 5th gear goes at a full 116 km speed at 3 thousand revolutions.
alone, it does not indicate whether this vehicle is fast or slow
08.05.2020 15:22 # 17
106_arts
Such a thing is neither possible in this world nor in any other place has been very irrelevant.
this gearbox is something related to the gear ratio
Also in this 206, nothing is done as a sibob setting, and the vehicle makes its own;)
08.05.2020 15:22 # 18
[QUOTE = 106_arts] [QUOTE = xdesign] A good concealer puts him at 130 in 3 thousand with a nice valve setting (dot)
My brother said I like you, but his friend is asserting, what am I to say?
The so-called face is the translated translation prince. it has nothing to do with power.
Anyway, who understands, understands, I can not assert any more ... Respect you all. Sırıtma
the cecol 2011-05-02 20:16:40
08.05.2020 15:22 # 19
We understand you very clearly. no problem :)) By saying the gear ratios, I mean all of them in general :))
the cecol 2011-05-02 20:12:14
08.05.2020 15:22 # 20
azdek
It didn't feel like normal to me but it knows the users better
Page : / 4
