About oil care (your suggestions)
08.05.2020 20:59 # 1
GiTaRRa
2006 206 hdi
friends 10/40 mi
Should we use 5/30
gitarre 2018-08-07 21:06:43
08.05.2020 20:59 # 2
Selcuk55
10 40 sibling factory suggestions, this is already 5 series or 0 40 0 50 Mercedes BMW Audi 5 5s or something about 30 thousand a year in minibuses and over-road vehicles
08.05.2020 20:59 # 3
Ahmetaltan
I am thinking of using castrol magnatec 5 * 30 c2 in the next oil change, which is the oil I am currently using. Ahmet Altan 2018-08-07 23:35:00
08.05.2020 20:59 # 4
GokhaN
In this oil selection, the performance and condition of the engine is also effective, but when the car goes over 130 thousand, I recommend 10w40, otherwise the thrusters start making noise, and then they may have trouble.
08.05.2020 20:59 # 5
GiTaRRa
thanks for your suggestions, friends
08.05.2020 20:59 # 6
Ahmetaltan
What was your decision after this post.
08.05.2020 20:59 # 7
KvncKR
You can get a motul, your car runs less loudly
tow trucks also use 20w50 in general 2015 corollam var factory suggestion castrol 5w30 but since it is drying in castrol engine, i use either motul or mobile according to the situation
08.05.2020 20:59 # 8
HasGur
in Turkey
Motor oils, which are praised without knowledge, recommended, preferred ... because they sell a lot; There is a problem with ignorant abuse, called stay away, almost unused ... almost 10 times more wear than cheap oils because it sells less, but the problem is that every individual from 10 year old baby to 70 year old man, illiterate and undergraduate graduate. to know everything!
Do not decide without researching the end-user tests of the oil or seeing how it compares to other oils. Even if it is not in Turkish, there are many sources that show the results with mathematical signs (!) That can be understood by almost everyone.
08.05.2020 20:59 # 9
HasGur
[QUOTE = Ahmetaltan] I am considering using castrol magnatec 5 * 30 c2 for the next oil change in the total oil change I currently use. [/ QUOTE]
All brands will recommend 5W30 ... The clerk says "Oh, this model suits you very well" for every jacket you try ... Same approach!
If you have been using oils such as 10W40, 5W40 for a long time, 5W30, 0W30 etc. When you start to use it, you will start to encounter oil leakage problems from different places at the 2nd latest, 3rd oil change or maybe a few thousand km after the first change. The first places you will see sweats will be crank seals and intermediate sump. The cost of replacing the 40 lira rear crank seal will be up to 500 liras, and worse, cutting the leakage in the intermediate sump will cost around 1500 liras!
08.05.2020 20:59 # 10
talip206
[QUOTE = HasGur] [QUOTE = Ahmetaltan] I am thinking of using castrol magnatec 5 * 30 c2 for the next oil change in total 5 * 40w. This was the oil recommended for our vehicles in the selection of castrol flour. My car is 206 hdi x design 2006 at 160000 km. [/ QUOTE]
I agree, teacher. When I first bought the car, there were 10 40 on it. I put 5 30 as a synthetic stuff. He sweated from all sides. It started to leak from the upper crank seal and the top rocker seal.
08.05.2020 20:59 # 11
ismailkaya
As the engine oil thinens, I know that the engine decreases, so the engine burns oil
