about oil
08.05.2020 15:22 # 1
ask307
Hi friends; In my previous maintenance, we put a total of 10-40 oils, I bought oil in the current maintenance castrol edge 5-40 Do you make any negative in the car after 5-40 10-40?
08.05.2020 15:22 # 2
mimitt
All this time, why did you use 10/40, which is the recommended 0W40 or 5W40 for your vehicle, so I think it will be better. I will even suggest you in the next maintenance, it will be a more effective oil for your mobile super 3000 x1 5/40 vehicle.
08.05.2020 15:22 # 3
I would not even say it would be even better based on my personal experience. Koliva 2011-05-02 16:28:52
08.05.2020 15:22 # 4
I used to put 10-40 total quartz 7000 as I was in a hurry before that.
this time I put the mobile-1 new-fiber 0-40 ... now like butter :)) on the highway so tight but not diminished even though I didn't close it on the dial :))
Besides, you can be comfortable, we don't have anything :)) You use a much better oil when you use it before ...
the cecol 2011-05-02 16:36:44
08.05.2020 15:22 # 5
metin
cem brother my care is approaching. I want to use a nice yak rather than the original, but I don't understand at all which one should I use.
08.05.2020 15:22 # 6
mimitt
I think research mobile oils, I have used a lot of esso in 406 for years, put a total of two times, esso has become a bit difficult to find, but now we have a mobile ci, very good oil everyone is very satisfied and maintenance intervals are longer than many brands.
You can reach the oil types recommended by Mobil for this vehicle from this link.
08.05.2020 15:22 # 7
tugrahan
What are the differences between 10/40 and 5/40 and 0/40
so what is the plus minus to the engine
in the last maintenance I put castrol magnatech 10/40
08.05.2020 15:22 # 8
[QUOTE = tugrahan] What are the differences between 10/40 and 5/40 and 0/40
There used to be summer and winter oil changes in trucks and trucks. In other words, they would put the vehicle in the maintenance and let me give you an example with the numbers you gave. Then when the weather got warmer, they would make another care towards the summer and thicken the oil. Now, with the development of technology, the advancement of nanotechnology and the widespread use of polymers, it has now eliminated these processes and it has been provided that the oil fluidity can change depending on the temperature. In other words, 10W-40 oil, which you call right now, can be fluid number 10 when it is cold and number 40 when it is hot. If I need to peel in more detail, the polymers in the oil grow longer as the temperature increases and cause fluidity to decrease. In this way, the oil thickens.
Therefore, there is no difference between 10W-40 oil and 5W-40 or 0W-40 when the engine is hot. So their fluidity is 40. However, when the engine is cold, that is, the oil is cold, 10W-40 oil flow is 10, the other 5 is zero.
I hope I could give some idea.
08.05.2020 15:22 # 9
10/40 semi-synthetic, 5/40 or 0/40 fully synthetic. Fully synthetic oils provide thinner, quicker lubrication in cold temperatures. The replacement range of fully synthetic oils is 5,000 km longer. Fully synthetic oils are more expensive Dil Çıkarma
08.05.2020 15:22 # 10
tugrahan
we learned that too thanks
08.05.2020 15:22 # 11
[QUOTE = text] cem brother my care is approaching. I want to use a nice yak rather than the original, but I don't understand at all which one should I use. [/ QUOTE]
I don't have anything to do with my original orgy. It does not produce any special oil for its total firing peugeot engine. Producing companies deal with a certain brand depending on the situation and in this way they recommend that oil. Besides, this is a commercial. Of course, at this point, the brand quality of the car is important.
Now everybody thinks totalini original, my tool is total or esso in user manual. esso is the same as the oil we call :)) the names of the two are exxon mobile. At this point, if you look at the esso or mobile, there is no original oil :)).
If we leave this original conversation aside and look at the oil of our vehicles
10-40 semi-synthetic
5-40 full synthetics
0-40 is full synthetic.
If we compare castrol magnatec with a total of 10 to 40 samples, it is obvious that magnatec is better. one is 40-45 lira and the other is 50-55 lira.
but i'm attitude, put better oil on your vehicle, use it for a long time. If the engine is constantly working with better oil, it will have a longer vertebra naturally.
You can add a little more than giving money to magnatec and use mobile super 3000 x1 5-40 or you can buy 0 to 40 new mobile phones for 100 TL. the choice is yours...
these samples are also available in castrol or other brands as well :))
If we are going to be aware of 10-40 and 5-40 or 0-40, I told you before but I'll tell you again :))
10-40
5-40
0-40
we said the differences of being semi-synthetic and synthetic
their fluency is the same when this tip warms up in the oil ...
so where is the difference ??? Fluidities are different when the engine is cold .
0-40 fat is the thinnest when cold, 5-40 fat is thicker, 10-40 is the thickest among them
In this case, when the engine is cold, it will minimize the wear by making a much faster lubrication than 0-40 oil others. This is the biggest difference :))
0-40 oil is not used in summer. People who do not know these heats are robbed of heat. consequently they have the same fluency when they get warm. If we put 0-30 oil, they might be a little bit right. because when it warmed up, it could stay thin because it was number 30 :)))
do not just connect the event to the cold of the air. the oil is cold when the engine oil does not reach 50C. it becomes hot after this point.
When you start marching with a knife in the summer morning at 25-30C, you will start a cold engine again.
however, it can be compared with a situation in the engine that reduces the oil. Reduction can be more when cold ...
the cecol 2011-05-05 09:48:05
08.05.2020 15:22 # 12
trtolgi
useful information.Thanks.
08.05.2020 15:22 # 13
We need to fix such information somewhere. you have to give a direct link when you ask
I'm tired of writing as well :))
08.05.2020 15:22 # 14
don't be angry my dear I learned what I wrote above from what you wrote. Everyone will learn something as they read. Teaching requires patience, so it is a sacred profession.
08.05.2020 15:22 # 15
no dear not to be angry :)) but writing the same things can sometimes be boring. But when you say you're right, teaching is hard. I know well because I'm a trainer Gülme
08.05.2020 15:22 # 16
orhanetap
Yesterday I put 5-40 oil on my vehicle because it is 100% synthetic, the price is a little expensive but there was an incredible change in my car, the sound decreased, the traction increased, I would consider putting boron. Sırıtma
08.05.2020 15:22 # 17
[QUOTE = orhanetap] Yesterday I put 5-40 oil on my car, because it is 100% synthetic, the price is a little expensive but there was an incredible change in my car, the sound decreased, the traction increased, I would consider putting boron. Sırıtma [/ QUOTE]
Which brand did you get?
08.05.2020 15:22 # 18
orhanetap
[QUOTE = koliva] [QUOTE = orhanetap] Yesterday I put 5-40 oil on my car, because it is 100% synthetic, its price is a bit expensive, but there was an incredible change in my car, sound decreased, traction increased, I would consider putting boron master 100% synthetic oil, I gave up absolutely and strongly. I would recommend Sırıtma [/ QUOTE]
The brand of oil is motul. It was a French brand and was producing only oil, making 2-3hb increase in mobile tests on the internet.
I heard it for the first time, I hesitated its name for a little bit but I am very happy because I do not know, but the car flows like oil Sırıtma
I don't know if the brand is important or it is 5-40 full synthetic but there was a serious difference in my car :)
08.05.2020 15:22 # 19
trtolgi
You can look at the web pages of companies that sell oil suitable for your friends.
08.05.2020 15:22 # 20
goktug
[QUOTE = ask307] hi friends; In my previous maintenance, we put a total of 10-40 oils, I took the oil in the current maintenance castrol edge 5-40 after 10-40 5-40 do any negative things in the car [/ QUOTE]
how many liter of castrol edge?
Page : / 2
