About Injector Cleaning.
08.05.2020 19:20 # 1
raconcu
Hello friends, first of all, I wish everyone good forums. My car will be the 2006 model 307 1.6hdi km newer 136,000. I am thinking of putting a würth diesel injector cleaner on my vehicle. But is there really benefit? How full should the tank be? Did the previous owner put it or not, would I have problems if I put it? I expect help from experienced friends.
08.05.2020 19:20 # 2
peugeot murat
I guess ask the company that sells how to use it as soon as possible.
08.05.2020 19:20 # 3
Alicilik
I highly recommend Würth or Berner. I used both and I couldn't see a difference between them. There is information on how to use it. It is usually 300ml. When the vehicle is half tank, I go to the oil and empty it first. (Don't let the vehicle touch your body or your skin) Then I fill the depy full and use it until the tank is finished.
My advice is to use it at least every 10000 km, but it's your pleasure. Because you can increase the usage according to the fuel quality in your region.
I am trying to use the vehicle with a little more performance in the doped tank, which is useful to keep the injector pressure high and improve the performance of the cleaner.
Another note is useful to do this just before maintenance. If you enter the maintenance at the end of the tank, it will be a more comfortable engine with other changes of the vehicle and you can see more clearly that the injector cleaner has not been the plus minus in maintenance. In some injectors, when the institution cannot be discarded, it can perform jerky work on the vehicle.
08.05.2020 19:20 # 4
KIZILASLAN
I think connect the most robust to the carbon clean device, both the injectors and the valves are completely cleaned.
08.05.2020 19:20 # 5
ersin61
Dude what is the cost of this carbon cleaner. Thanks ..
08.05.2020 19:20 # 6
KIZILASLAN
60 TL
08.05.2020 19:20 # 7
ersin61
Thanks...
08.05.2020 19:20 # 8
ahmet_bjk
Hello there,
Should I use würth's fuel additive or carbon clean for 1.6 HDI at 70.000 km?
(there is some noisy engine running and jerky operation when first running)
