About idle
08.05.2020 17:08 # 1
DeRyCK
I removed the throttle and cleaned it a few times. I think the butterfly's calibration is broken. Idle play occurs even if there is not much fluctuation. Can I do the calibration myself? There are programs such as ELM 327 connectors and scanmaster, can I play data with them? Thanks in advance.
08.05.2020 17:08 # 2
halowman
& nbsp; When I say playing, my engine & nbsp; titriyo "Questi I wonder if the throttle is being felt in my mind "Unhappy"
08.05.2020 17:08 # 3
I'm not sure it will happen with those devices, but I'm not sure. You can do it with PP2000.
08.05.2020 17:08 # 4
DeRyCK
There is a section in the scanmaster program called pid configuration. I looked at whether there is a setting from there, but I think it is not. I guess it's best to go to the service and have it done. When I say
& nbsp; Normally the motor vibrates when the speed drops. When giving and releasing gas, up to 2 thousand revolutions descends normally then descends slightly slower.
08.05.2020 17:08 # 5
falan
the idling engine is probably broken .. it will not be useful to clean it as much as you want .. i recommend you to change it directly .. around 200 original .. sub-industry 70-80
08.05.2020 17:08 # 6
DeRyCK
I got out of the service, I replaced it completely with the butterfly, but it still did not improve. I found the original idle engine to 135 but I don't want to buy it without making sure what the problem is :)
08.05.2020 17:08 # 7
MEREN
08.05.2020 17:08 # 8
MEREN
Greetings friends 96 model 306 & nbsp; I have the same idling problem in S16, my master said that we need to replace the rolent sensor, I bought 382 zeros and took it to the special service, but they said that the trouble was in the throat butterfly, I learned that the original was 1,000 TL and was not in the market. I would be very happy if they can help if there are friends who have these troubles.
08.05.2020 17:08 # 9
mmuussaa
Guys, I would like to have the spark plugs checked. It can also be caused by spark plugs.
08.05.2020 17:08 # 10
DeRyCK
I had an iridium spark plug installed but the problem started when I broke the idling engine when I disassembled the butterfly. I don't think it will be spark plugs.
08.05.2020 17:08 # 11
herdemo
Hello, I had a similar problem as well, especially when idling, the tachometer was constantly in play. I took it to the service, could not find a reason for service, one day the car was connected to the computer, they said that they would connect from France and find the problem. They handed over the car the next day, saying they had made a change in the software and that the situation had improved. However, the problem persisted, I took it to the service again, this time they replaced the thermostat and a few cables connected to it. I don't have any trouble for now. The vehicle was measuring the engine temperature incorrectly and delivering gas. & Nbsp;
08.05.2020 17:08 # 12
sabrig
[QUOTE = DeRyCK]
I got out of service, I replaced it completely with the butterfly, but it still hasn't improved. I found the original idle engine to 135 but I don't want to get it without making sure what the problem is :) My vehicle was stopping, when I pulled it out of the gas, at the moment, the master pulled out the plug, while the idling & nbsp; engine was just cold, the idling remained low.
08.05.2020 17:08 # 13
caster21
If the car is LPG, do not look for a waste solution. It is the same as LPG. It went even further. It stopped when idle. Sometimes we changed the idle engine. We changed the throat butterfly. It did not work. Then I used the car at 100 150 km. Vehicle 2000 model 206 XR 1.4 Ramses LPG attached (Damn Brand Briefly)
08.05.2020 17:08 # 14
DeRyCK
My vehicle is not scuba, I will show it to the service as soon as possible.
