About Glass Automat
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 208
08.05.2020 19:56 # 1
VaHaP23
I took it to the service yesterday, the window on the driver's side was coming down automatically, but it was constantly pausing as I was going up, pressing it repeatedly and closing it. Someone in the service immediately did something for 10 seconds. But after coming home from the service, I had the same problem, I watched the man, I held the key a little bit like him, and I pulled it down when I pulled it up, but the problem is that every time I stop the car, the setting is reset, the glass does not go up automatically, I have to do the same operations again. ? Confused
08.05.2020 19:56 # 2
teacher, if the coding is constantly deteriorating or the 4-way glass opening control group is problematic, which is generally oxidation etc. if he can. I think if your vehicle's warranty continues, have it checked by the service.
08.05.2020 19:56 # 3
VaHaP23
The warranty of the vehicle was finished 3 months ago Only the driver's window is doing this.
08.05.2020 19:56 # 4
I do not think it will be related to the brain. Glass button rainy weather or water enters the door between the keys. This can cause problems in many vehicles. it may be in a condition related to the glass removal module. If the vehicle has been serviced until now, you have the opportunity to get an extra discount. You can even get a peugeot extended warranty. 36 months extra warranty should be around 700 TL.
08.05.2020 19:56 # 5
Premium
Hello, I also have 307 and I am having similar problems. I disassemble the driver control panel, clean the panel with the circuits nicely and put it back in. Instead, all the problems go. I would recommend to the industry in the industry door to door and don't be grateful to the electricians because they don't want to deal with it as a simple job. Wink
08.05.2020 19:56 # 6
VaHaP23
Thank You I Will Consider Your Recommendations
08.05.2020 19:56 # 7
emrepunar
I had the same problem with 307 sw, although it did not improve despite changing the door unit, sometimes it was stuck.
08.05.2020 19:56 # 8
aykutcerit34
Hi
Generally, malfunctions are caused by the glass button.
thanks..
08.05.2020 19:56 # 9
VaHaP23
[QUOTE = aykutcerit34] hello
thanks..
What would you like to help? Are you close to the Gulf
08.05.2020 19:56 # 10
Fthz
A condition that falls into the class of chronic malfunction. The control was not cleared, the control was not completely changed, etc. etc. I could not find a solution. I think he did it because of an irregularity / malfunction in electrical installations rather than control or keys, but I cannot derive a solution.
08.05.2020 19:56 # 11
VaHaP23
[QUOTE = Fthz] A condition that falls into the chronic malfunction class. The control was not cleared, the control was not completely changed, etc. etc. I could not find a solution. He thinks he did it because of an irregularity / malfunction in electrical installations rather than control or keys, but I cannot derive a solution. [/ QUOTE]
This weekend, I will see what the problem is, it makes me crazy, even if my hand is stuck, the glass does not come out, I always have to do a push and pull. Angry
08.05.2020 19:56 # 12
aykutcerit34
[QUOTE = VaHaP23] [QUOTE = aykutcerit34]
Hi
thanks..
08.05.2020 19:56 # 13
aykutcerit34
Even if you are not close to service in Istanbul 4 levent, I will help you with the topics you can ask the masters about the authorized service.
25.07.2020 23:25 # 14
esk2626
Hello, this problem is over for me. how was the solution found?
31.07.2021 11:41 # 15
cagoto3535
Hello, the problem occurred with me too, I pull the same key up and reset, it gets better, but it comes back gradually. Anyone able to solve the problem?
