about gearbox oil
08.05.2020 15:27 # 1
ask307
Hi friends, I had a problem with the gear shift of the vehicle changed 1 month ago.
08.05.2020 15:27 # 2
metin
I looked at the service box and there it says 75W80W-EZL848-2Liter for "BE4 L MECHANICAL GEARBOX"
08.05.2020 15:27 # 3
azdek
Friends, when I went to the last service, I said that the gearbox oil would change, and the gear shifts were starting to get harder.
08.05.2020 15:27 # 4
sercinho
What if this gearbox oil changes, does it have a certain time, automatic gearboxes change different times in manual gearboxes
08.05.2020 15:27 # 5
monur
[QUOTE = sercinho] or how long does this transmission oil change? Is there a certain time for automatic gearboxes?
Honestly, I did not understand the policy of this Peugeot. Its automatic transmission is German based. 70% of German vehicles change an oil at 45,000 km but Peugeot says life.
08.05.2020 15:27 # 6
ose
erased
kankam_743 2011-05-24 04:11:04
08.05.2020 15:27 # 7
oguzhan29
friends, let's share, let us know, at which intervals and which brands of the gears are
08.05.2020 15:27 # 8
monur
[QUOTE = kankam_743] both manual and automatic gearbox oils change and also change in peugeot. See user manual for km [/ QUOTE]
It is shown as a line in the user manuals.
08.05.2020 15:27 # 9
monur
[QUOTE = oguzhan29] friends, let's share, let us know, at what intervals and which brand of gears are gears [/ QUOTE]
It is normal for 50 thousand on the basis of KM. It is not an oil that loses its properties unless it leaks.
08.05.2020 15:27 # 10
ose
[QUOTE = monur] [QUOTE = kankam_743] both manual and automatic gearbox oils change and also change in peugeot. See user manual for km [/ QUOTE]
Yes, you were right, I'm sorry, I have mixed with brake fluid, it does not change, just check the gearbox oil for automatics every 60,000 thousand and complete, it says nothing for manuals. So nothing happens to these oils. My advice is to look at the level if there is sweating.
08.05.2020 15:27 # 11
Haksen016
thinks they are trying to come back when it breaks down, 60 thousand km. commutative.
08.05.2020 15:27 # 12
The structure of Allah is deteriorating, these are the servant structures. At worst, the clutch pressure should be replaced when replacing the pad. Level control should be done every six months, and it should be changed without remaining 100,000 km. This is for manual (I don't think of Turkish) gears. In my previous vehicle (1999 model 1.4 103.000 km Palio) I changed 72.000 km. I saw a lot of benefits. Both in gear shifts and in fuel. I bought my current vehicle 172,000 km. I will change it again, but this time with the press pad.
08.05.2020 15:27 # 13
ask307
when I drained my transmission oil it turned out like molasses, it seemed that it lost its oil feature
08.05.2020 15:27 # 14
I also changed my transmission oil. I was good at changing. I had more comfortable nights than before.
I put 2 LT Esso 75W-80
08.05.2020 15:27 # 15
ose
Even if the service says 'Service is unchanged', I changed and I saw many benefits. I even have a friend who adds boron with added additives.
08.05.2020 15:27 # 16
voodoo
How should we put an oil, I wonder how to put it for the gasoline 2.0 gti 206
08.05.2020 15:27 # 17
hantsome28
friends on May 19, I went to peugeot service to change the gearbox oil on May 19. From time to time, there was a sound called blunt and therefore I wanted the gearbox oil to change. And I insistently told them to make a change. They said, let's lift the car on the fiber, let's see if there was any kidnapping. from time to time, I said that he did not leave position P while he was shifting back, they changed the sensor on the brake pedal. ar.
08.05.2020 15:27 # 18
[QUOTE = voodoo] how should we put an oil, I guess how to put a gasoline 2.0 gti 206 for [/ QUOTE]
You can also look at the technical book of the vehicle. If I gave 75W-80 oil as I wrote above, it could probably be the same as yours. You can put esso, mobile or total.
