About gasoline ECU reset
08.05.2020 20:23 # 1
Mehmet92_27
Due to the imperfection in the LPG, the gasoline values are broken, the car is drowning in gasoline, it does not eat gas, sometimes it stops at the first run and I wait until morning by inserting the pole and the vehicle is adjusted for 30 km. Is it enough to reset your map?
08.05.2020 20:23 # 2
sdttn
The most accurate result is seen when connected to the diagnostic tool. But there seems to be another problem in your case. It is not less than 30 km. If there are problems with both gasoline and LPG, the ignition system (coil and spark plugs), throttle and manifold leaks should be checked.
08.05.2020 20:23 # 3
Mehmet92_27
[QUOTE = sdttn] The most accurate result is seen when connected to the diagnostic tool. But there seems to be another problem in your case. It is not less than 30 km. If there are problems with both gasoline and LPG, the ignition system (coil and spark plugs), throttle and manifold leaks should be checked. [/ QUOTE]
Spark plugs zero in the car there is no glitch, no lpg, no trouble, it came to me earlier, it was an electronicsman who was reset with money, but after getting a while with lpg, the same thing happened again.
08.05.2020 20:23 # 4
sdttn
Shorten LPG injector hoses. Talk to the LPG master may suggest a different injector.
08.05.2020 20:23 # 5
Mehmet92_27
For a few days I get on the gas after this process, the car got flat and big
