about fuel consumption
08.05.2020 15:05 # 1
sercinho
hello friends 1-2 months ago, a friend said that if you do not throw on the bos in these electronically embedded vehicles, he said he would burn less fuel and ecu would adjust it by himself. , 0 is showing that the vehicle does not burn, it seems that sometimes I would go to the bus now I do not go anymore, this event continues in the same way after having lpg installed on the vehicle, do you have any information
08.05.2020 15:05 # 2
metin
I heard that new generation vehicles burn less in gear than idle. lpg also does not change, however, the consumption of lpgnin is slightly higher than gasoline.
If you are consuming 10 liters of gasoline, it will burn something like 11 to 11.5 liters in lpg. Since lpg is cheap, the fuel of the vehicle is already low compared to gasoline.
08.05.2020 15:05 # 3
insomnia
to find crime because it burns cars a lot
There is a crime in the system that turns gasoline into tax collection
paint the bottom of the trunk
08.05.2020 15:05 # 4
The issue you are saying is the cutoff issue, it continues in lpg. Even the vast majority of the problems I had in my lpg system were related to this cutt off setting. They corrected this setting, the car stopped pushing forward.
I've been laughing for half an hour at the picture: D
May Allah give you your goodness :)
the cover 2011-02-08 00:15:36
08.05.2020 15:05 # 5
ali oncu
situation in new vehicles, pull your foot off the gas in this gear :)
