About fault codes P0011 and P0420
22.05.2022 17:36 # 1
oktan24
Hello,
I bought 308 1.6 vti in March, the vehicle is at 154,000 km now and LPG has never been installed.
A few days after receiving it, it gave an antipollution faulty warning. It is customary for the newly purchased vehicle to be maintained, so I changed my oil maintenance and timing chain set, saying that I would be comfortable. I cleaned the front solenoid valve. I put Shell' Helix 5/30 engine oil, which I think is of good quality. div>The vehicle is emitting smoke and there is an odor from the exhaust.
When I connect with elm327, P0011 and P0420 faults appear
If I replace the electrovalve of the vehicle and clean the catalyst, will my problem be solved?
Your friends with experience i need your ideas
27.05.2022 22:54 # 2
oktan24
I changed the electrovalve of the vehicle, the smoke stopped, the antipollution fault warning is no longer giving and I feel like the traction has increased
I am observing the oil reduction situation
Everything seems to be back to normal now
28.05.2022 18:42 # 3
Katip55
I know that oil reduction is normal in these vehicles. I think it's around 1 liter per thousand km. Congrats on your other pipe.
13.08.2022 20:44 # 4
tyanaarge
Can you specify which part you changed, the exact part name, location etc. I have the same problem, thanks in advance..
20.08.2022 11:50 # 5
oktan24
The part numbered 1628924280 is called electrovalve. There are 2 pieces in the vehicle, one in the front and one in the back, I changed the front one and had the other one cleaned, my teacher
