About fast flashing signal (Solved)
08.05.2020 20:50 # 1
TugbayDundar
Hello friends,
The light blinks fast when I signal left, no problem when I signal right.
I learned that this happened when one of the bulbs was not lit, and when I checked it, I saw that the front left signal was not lit. I removed the bulb on the left, put it on the right side and the bulb is not broken, it is on the right. I checked the cables of the left side as if it were okay.
Can you cause a problem, can we help?
tuğbaydünd is 2018-04-10 10:13:14
08.05.2020 20:50 # 2
GokhaN
In this case, the areas to be controlled are in order of priority.
1-) com 200 (signal lever complete)
2-) fuses
3-) relays
08.05.2020 20:50 # 3
[QUOTE = GökhaN] in this case, the fields to be checked are in order of priority
2-) fuses
3-) relays
Also check the sense that will be a plus, brother.
08.05.2020 20:50 # 4
pusutr
Such a situation happened to me. One of the previous owners tried to make an American park, and the problem was that the cable was attached to one of the signals. I disassembled the joint and cut it from the end a bit, my solders problem disappeared.
08.05.2020 20:50 # 5
TugbayDundar
Thanks for your suggestions.
There was contactless in the cable to the signal, I made the connection again and the problem was improved :)
Thanks to you, another problem has been solved.
