About Engine Oil
08.05.2020 20:58 # 1
YNR
Hello guys, I am new to both the car and the forum. I want to ask something. When the engine oil is low, if we put the new oil on it without draining or replacing the old oil, would there be any problem. By the way, I do not know what the old oil is, since I just bought the car, but I know that the oil I will put will be 5-30. thanks
08.05.2020 20:58 # 2
GokhaN
Let us help you whatever thousand km of vehicle you provide.
08.05.2020 20:58 # 3
YNR
2006 - manual -1.4 diesel - vehicle at 178000. the person I bought had maintenance in 173000..but I would like to see an oil anyway.
08.05.2020 20:58 # 4
YNR
206 by the way :)
08.05.2020 20:58 # 5
GokhaN
If the engine performance is good, I recommend using 10w40 if 5w40 is not available, 5w30 remains a bit thin
Elf, Mobil, Total, Castrol in my ranking as Brand
08.05.2020 20:58 # 6
YNR
Thank you very much for your answers and suggestions. By the way, does it mean that you can put a new one on it without draining the old oil.
08.05.2020 20:58 # 7
GokhaN
I do not recommend adding 5w30 already in expensive overhead. You take care of oil
Oil
Oil filter
Air filter
I recommend you change the pollen and diesel filter.
08.05.2020 20:58 # 8
YNR
I understand..thank you very much..thank you
08.05.2020 20:58 # 9
talip206
[QUOTE = YNR] Thank you very much for your answers and suggestions. By the way, does it mean that you can put a new one on it without draining the old oil. [/ QUOTE]
You can add if you know the brand and quantity of oil currently in the engine and if there is a serious decrease in engine oil.
But if you don't know about the previous oil, don't add. It is not good to mix different oils.
08.05.2020 20:58 # 10
YNR
Thanks suitor. thanks
