About Diesel Filter ...
08.05.2020 16:32 # 1
Dostum
Hi Friends ... My vehicle, 307 SW 1.6 HDI. I put a fuel-injector system cleaner in the fuel tank. My first impressions were very positive, the engine noise decreased, the agility increased. Only after about 150 km of roads went on the same day, I stopped the car. Like the light bulb that came in less, it worked wavy, when I touch the gas it plays normally, there is no problem while going on the road. Is there any water accumulation, how to check it, I would be happy if there is a figure and illustrated expression ... By the way, there is no system malfunction in the road computer ... I just want to change the diesel filter myself ... Can I change it alone, after changing the vehicle need to introduce to the system Does it have ... Are there pictures and videos for filter replacement ... I also want to install the original diesel filter ... I searched on the internet, Delphi, Bosh and companies whose name is not known have a diesel filter. , is there a suitable site or seller ... I'm in Antalya ... Best regards ...
08.05.2020 16:32 # 2
yavuz25
Get past. Do not put the diesel additives into your car. Do not put it into your vehicle. Finish that tank, reset it. After a while, do not fill the diesel. After 2 warehouses, your vehicle will recover. The same situation has happened to us. "Wink"
08.05.2020 16:32 # 3
06OzGuR06
I use the injector cleaner additive of a local brand called CARPEX. I used it 5-6 times, it saves fuel but I didn't see much increase in power. "Smile" I did not see any damage. On 5000 km to 1 tank (55-60 liters) & nbsp; Adds 250 ml in the form of writes. I emptied a tank at 10,000 km before flushing it. "Smile" There was no misfire ever after use.
< br> This is the product;
08.05.2020 16:32 # 4
Dostum
[QUOTE = ezelefe] Let me change the diesel filter, you know, a master who knows.
For our original product, you can ask for peugeot murata.
& nbsp; Why can't I change it myself? ...
08.05.2020 16:32 # 5
Dostum
[QUOTE = ezelefe] because this filter is not like pollen air filter.
is on the right-hand side of the engine.
If you have the skill, I can not say anything, but it is more healthy for someone to know
& nbsp; Observed & nbsp; the pipe attached to the old filter and the sender can not be installed in the new one ... After all, the air filter was also on the top of the engine (under the windshield) & nbsp; I had some difficulty, but I installed it ... Is it more difficult to install the diesel filter than this ... Best regards. ..
08.05.2020 16:32 # 6
yavuz25
[QUOTE = 06ÖZGÜR06] I use the injector cleaner additive of a local brand called CARPEX I used 5-6 times saving fuel but I did not see much increase in power. "Smile I did not see any damage. On one 5000 km (55-60 liter) & nbsp; Adds 250 ml in the form of writes. I emptied a tank at 10,000 km before flushing it. "Smile" There was no misfire ever after use.
< br> This is the product:
http://www.hepsiburada.com/Liste/carpex-dizel-arac-yakit-katkisienjektor-temizifying-09e012/productDetails.aspx?productId=otm09e012&categoryId=26005#Gorseller
Oh, brother, do not add to the car.Euro already has enough contribution, the rest is nonsense. I put your king, the mother of the car cried. I can't get them if they give it for free. "Wink"
08.05.2020 16:32 # 7
yavuz25
[QUOTE = Dude] [QUOTE = ezelefe] because this filter is not like pollen air filter.
is on the right-hand side of the engine. Observed & nbsp; the pipe attached to the old filter and the sender can not be installed on the new one ... After all, the air filter was also on the top of the engine (under the windshield) & nbsp; I had some difficulty but I installed it ... Is it harder to install the diesel filter ... .. [/ QUOTE]
The
diesel system is not like a gasoline system, it makes air, pressures, breaks, cracks, trouble. /smiley2.gif "border =" 0 "alt =" Wink "title =" Wink "/>
08.05.2020 16:32 # 8
06OzGuR06
[QUOTE = yavuz25] [QUOTE = 06ÖZGüR06] I use the injector cleaner additive of a local brand called CARPEX 5-6 times it saves fuel but I did not see much increase in power. I have not seen any damage. 1 tank (55-60 liters) at 5000 km & nbsp; Adds 250 ml in the form of writes. I emptied a tank at 10,000 km before flushing it. "Smile" There was no misfire ever after use.
Oh, brother, do not contribute to the car. Euro is already enough, the rest is nonsense. If you love your car, do not do anything. I put your king, the mother of the car cried. I can't get them if they give it for free. "Wink"
OK, brother, I don't put it if you say harmful "Smile" So I don't have a performance drop, but I don't want to contribute "Big
But if there is no contribution in the right fuel you said, I need to put it now not already. "Wink" "
08.05.2020 16:32 # 9
yavuz25
[QUOTE = 06ÖZGÜR06] [QUOTE = yavuz25] [QUOTE = 06ÖZGüR06] I use the injector cleaner additive of a local brand called CARPEX 5-6 times, I was saving fuel but I did not see much increase in power. I did not see any damage.It adds 250 ml to a tank (55-60 liters) in 5000 km and use it. Before emptying a tank at 10,000 km, I empty it. There was no misfire ever after using this product. ] oh my brother, dont add to the car.Euro already has enough contribution, the rest is nonsense.Look if you love your car dont add anything.I put your best king, the mother of the car cried.If they give it for free again, I can't get it. [/ QUOTE] I thought that it would be useful when using it and it was useful when it was used regularly.That is, I do not have a performance decline, but I was contributing to not to drop it.But if you do not have any contribution in the correct fuel you are saying, it is not necessary anymore. The vehicle can reveal the damage in the long term. After you put the euro, nothing will happen with the permission of Allah. The most important feature of the additives is Lubricate the roads for the passage of zot. Lubricates all of the fuel pipes and elements, so what seems to be useful, guess what damage causes. What ideas we can run from here.
08.05.2020 16:32 # 10
06OzGuR06
The lubrication is a good thing, of course, in terms of pumps and injectors, but as far as I know there is oil in the diesel, "Smile" & nbsp; Perhaps there are eurodiesel in the contributions then the air becomes mercury & nbsp; because 250 ml of fuel additive is 10 TL. "LOL" & nbsp; Best of all I am going to continue with the doped eurodiesel now it is stuck in my head now I do not add any more contribution & nbsp; "LOL"
08.05.2020 16:32 # 11
yavuz25
[QUOTE = 06ÖZGÜR06] Lubrication is a good thing, of course, in terms of pumps and injectors, but as far as I know there is oil in the diesel already "Smile" & nbsp; Perhaps there are eurodiesel in the contributions then the air becomes mercury & nbsp; because 250 ml of fuel additive is 10 TL. "LOL" & nbsp; Best of all I am going to continue with the doped eurodiesel now it is stuck in my head now I do not add any more contribution & nbsp; "LOL" [/ QUOTE]
brother diesel is the number 10 oil right you know. "Wink" There are gasoline alloy lubricants and abrasives in additives. So it is unreasonable to lubricate the places where oil, which is already oil, passes with an abrasive oil. Well, let me tell you what happens as a result. Corrosive lubricants, namely additives value everywhere the diesel touches and damage the seals of the pump elements. Then the ejector voiding problem, diesel pump pressure problem, diesel incontinence problem, etc. emerges. tut is a humble friend recommendation, my brother. "Smile"
08.05.2020 16:32 # 12
Dostum
[QUOTE = Dude] Hi Guys ... My vehicle, 307 SW 1.6 HDI. I put a fuel-injector system cleaner in the fuel tank. My first impressions were very positive, the engine noise decreased, the agility increased. Only after about 150 km of roads went on the same day, I stopped the car. Like the light bulb that came in less, it worked wavy, when I touch the gas it plays normally, there is no problem while going on the road. Is there any water accumulation, how to check it, I would be happy if there is a figure and illustrated expression ... By the way, there is no system malfunction in the road computer ... I just want to change the diesel filter myself ... Can I change it alone, after changing the vehicle need to introduce to the system Does it have ... Are there pictures and videos for filter replacement ... I also want to install the original diesel filter ... I searched on the internet, Delphi, Bosh and companies whose name is not known have diesel filter. Which one would you recommend? There are also gaps between prices. , is there a suitable site or seller ... I am in Antalya ... Best regards ... [/ QUOTE] Friends are still unanswered clearly ... My answers are turned around whether or not to contribute ...
08.05.2020 16:32 # 13
06OzGuR06
[QUOTE = Dude] [QUOTE = Dude] Hi Friends ... My vehicle, 307 SW 1.6 HDI. I put a fuel-injector system cleaner in the fuel tank. My first impressions were very positive, the engine noise decreased, the agility increased. Only after about 150 km of roads went on the same day, I stopped the car. Like the light bulb that came in less, it worked wavy, when I touch the gas it plays normally, there is no problem while going on the road. Is there any water accumulation, how to check it, I would be happy if there is a figure and illustrated expression ... By the way, there is no system malfunction in the road computer ... I just want to change the diesel filter myself ... Can I change it alone, after changing the vehicle need to introduce to the system Does it have ... Are there pictures and videos for filter replacement ... I also want to install the original diesel filter ... I searched on the internet, Delphi, Bosh and companies whose name is not known have a diesel filter. , is there a suitable site or seller ... I am in Antalya ... Yours sincerely ... [/ QUOTE] Friends still have not been answered clearly ... My answers have turned around whether to contribute ... [/ QUOTE] In fact, what is written here can give you an idea of what kind of situations your vehicle may have, because after using the additive, you wrote that this situation has developed.
08.05.2020 16:32 # 14
yavuz25
[QUOTE = 06OzGüR06] [QUOTE = Dude] [QUOTE = Dude] Hi Friends ... My vehicle, 307 SW 1.6 HDI. I put a fuel-injector system cleaner in the fuel tank. My first impressions were very positive, the engine noise decreased, the agility increased. Only after about 150 km of roads went on the same day, I stopped the car. Like the light bulb that came in less, it worked wavy, when I touch the gas it plays normally, there is no problem while going on the road. Is there any water accumulation, how to check it, I would be happy if there is a figure and illustrated expression ... By the way, there is no system malfunction in the road computer ... I just want to change the diesel filter myself ... Can I change it alone, after changing the vehicle need to introduce to the system Does it have ... Are there pictures and videos for filter replacement ... I also want to install the original diesel filter ... I searched on the internet, Delphi, Bosh and companies whose name is not known have diesel filter. Which one would you recommend? There are also gaps between prices. , is there a suitable site or seller ... I am in Antalya ... Yours sincerely ... [/ QUOTE] Friends still have not been answered clearly ... My answers have turned around whether or not to contribute ... [/ QUOTE] In fact, what is written here can give you an idea about what kind of situations your vehicle may have, because after using the additive, you wrote that this situation has improved. Take the original oil filter from the authorized service (Haşim Balaban) and I would say that you have not changed it in any maintenance service in the industry. [/ QUOTE]
08.05.2020 16:32 # 15
Dostum
Friends ... Today, I bought my breath with my pejo master in the industry ... I explained the situation ... Let's replace the diesel filter ... Anyway, I bought a BOSH brand 1.6 HDI diesel filter from the particle. the filter was original, an unknown brand came out. But the water that came out of the filter & nbsp; surprised me ... I do not exaggerate, in front of my eyes, white water flowing close to 2 cups of tea is from the old filter .... According to the master, it's been for a long time He said that the filter has not been replaced or that much water has accumulated due to bad diesel ... After we drained the water, I said if we would use the old filter again ... It would be better to use it after accumulation of water, it would be better to change the new one. Anyway, a new one was installed, the fuel system and the filter were vented, I went about 10 km, the car relaxed but also importantly, the irregular work at idle has ended. Thank God ...
& nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; I understood that when the vehicle is bought without relying on anyone, it is necessary to put it in complete control ... I can not say anything to the man I bought the car, the ball is in the car that got in the car for 2 months. He said it will change.
& nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; After this filter event, & nbsp; construction.We will have a complete control of my vehicle, including the end of the week belts ... Peace of mind ...
08.05.2020 16:32 # 16
yavuz25
How long did you get the diesel filter?
08.05.2020 16:32 # 17
06OzGuR06
I wish you a happy and pleasant journey. Get back to your name "Smile" "Wink"
