About Depoolution
08.05.2020 18:17 # 1
baris558
Hello. I will ask for your help. & Nbsp;
I also have 2007 pejo 1.6 diesel 407. I bought the vehicle for about ten days. In the first depollution error, they replaced the spark plugs, the egr control and cleaning was done, it improved. Now he gave it again. But whenever I get my attention on the cruise control, it gives this error in a few minutes. First it gives esp error and then depollution error is multiplying. Then the esp error does not come up again, but depol. error constantly comes up. Depol error drops from the cycle when it first comes out, but in the next ones, there is no problem in the cycle. Then the motor error went out. I put the cruise control on again, and a minute later, the engine malfunction burned and stored. gave the error. Does it have anything to do with it? Or could it be related to flywheel?
08.05.2020 18:17 # 2
baris558
Thank you very much for your attention & nbsp; "Smile"
I write for information .
I went to the masters that they called very well in the industry. If I caught myself, they would change many parts of the vehicle. Starting from EGR to the air flow meter.
Then I went to the Sivas Peugeot Authorized service. Best of the services I have seen so far. I felt like at home. Professionals and craftsmen in their work. They didn't say let's change that. They did their complete checks. They found the turbo solenoid valve to be faulty. The problem has been solved. They did the vehicle in a general maintenance. The vehicle became a completely different vehicle. It was like a shotgun.
I think we need to encourage such dealers. I would like to thank Yusuf bey and Bilal Beye, Mrs. Damla (they questioned the satisfaction at every moment of the process) & nbsp; Ahmet Bey is a young and talented friend. He is doing his job devotedly, scientist.
baris558 2014-02- 17 17:19:04
08.05.2020 18:17 # 3
mistercasper
well, my nurses had the same fault with me, and the rail pressure sensor had changed, so I changed the sivas ofz pejo, a service that does its job really well, but a little expensive:) & nbsp;
08.05.2020 18:17 # 4
oguzhan29
thank you for the information you have received from the past, thank you to all the people who helped support the forum.
08.05.2020 18:17 # 5
baris558
Esp asr error comes out spontaneously when it gives depollution failure. Actually it is not a problem in esp. Since the motor goes to save, it also sees an error, but the esp system continues to run. & Nbsp;
When the engine is in fault position, you cannot activate the cruise control as long as the problem persists. The cruise control system also fails. If you can start the cruise control after a while, the problem is past. So it is a short-term error. But the engine malfunction light may not go out.
So with the cruise control, you can check whether the engine malfunction continues.
< div> My error starts with cruise control, my prediction was wrong. Just a coincidence.
It is not only the computer that matters to understand the error. It is necessary to know the vehicle well, read the errors well and know what to do. For example, in this error, I got my car attached to the computer in a few places. The solution proposal of all of them was different. But the friend at the service examined the car for about an hour, attached to the computer. They have different screens. There he studied the values for a while. He experimented. He did research.
So I think the service came to me much cheaper. So expensive is a relative concept at some point. For example, if I complied with friends outside, my expense could have reached 4 thousand TL until now. If you also add the warranty of the service, I think, the most logical decision was to have it made in the service. Some materials such as circlips of the filter were installed (4 * 7.5), & nbsp; and other engine equipment, such as egr, were tested and tested. it was. That's why I even changed my vehicle brand. Or when I go to the service in another city ... But if the service is professional and conscientious, don't be afraid, go and go.
08.05.2020 18:17 # 6
baris558
Hello,
I wanted to ask something.
What is Vacum electric valve. Does anyone know? I have the product code & nbsp; & nbsp; 9652997580 pejo. But I couldn't find it on the internet. Different products come out.
