About Cooling Water
Homepage » PEUGEOT MODIFIED PLATFORM » How To
08.05.2020 20:04 # 1
OguzhanKucuk61
When I opened the hood and checked the water, I saw that the water level was where I pointed with my finger. While he intends to add by saying that he has decreased, min. Max. I saw the icons and the water level was max. I realized he was at his level. I called my master, he said he'd already throw more than he should have been there. Logically, max. Min. I think he should be there when he sees his phrases. But since the master who put an antifreeze and the master who changed the radiator always filled it to his mouth, I always thought he was the right one. Even min above the water tank. Max. I thought there was no level indicator. He's my shame, it turns out. Is that actually friends? Should it be at this level?
08.05.2020 20:04 # 2
dejawu1978
Well, I've learned it now, thanks to you :) I was filling it up and I thought it was constantly decreasing water. I hope that this thesis is correct. I would appreciate it if it enlightens us with knowledge about it.
08.05.2020 20:04 # 3
OguzhanKucuk61
Just like that Ozan brother, add constantly, add constantly. I'm really surprised, this is the shame of Peugeot :) the human black writer is there so you can see it ?? :)) expect explanations from people who know :)
08.05.2020 20:04 # 4
Narkotik
Filling over Max can break the cap
08.05.2020 20:04 # 5
OguzhanKucuk61
[QUOTE = Narcotics] Filling over Max can break the cap [/ QUOTE]
So where is it where I pointed with my finger, or is it actually where it should be? It says 1.1 L above it. Is this the right level?
08.05.2020 20:04 # 6
xmen
Never exceed the Max level. The expansion vessel is already called. Since the existing water will expand when heated, there must be some space in the container.
08.05.2020 20:04 # 7
samet206
It is not advisable to fill it to the brim, it is an expansion vessel on its name, but for some reason the services complied with this rule, I did not come across it :) Since I added it myself, there is a black belt at the top of the canister or I fill it to the top belt, I did not have a problem on my own.
08.05.2020 20:04 # 8
OguzhanKucuk61
Got it, guys. Thank you very much for those interested. If I stay at the max level, I will follow for a few days. I never handle. Auspicious :)
08.05.2020 20:04 # 9
Radox
There is no problem at maximum but I always put more than maximum
there is nothing to be afraid of, but it is better to control both in summer and winter.
08.05.2020 20:04 # 10
talip206
Come on, they do the same with oil, whatever the water. At the time of oil change, they fill up to 4 liters of oil to the larynx. whereas it takes 3.25 liters including 206 filters. then it starts oil leaks problems.
08.05.2020 20:04 # 11
KILIC
Actually, max, hodja. The master may have filled it to his mouth before, but he asked the Lord to work and wait for you for a while, or he did it himself. that is, the master did not fill her to the brim in that way :)
08.05.2020 20:04 # 12
OguzhanKucuk61
It is true, teacher :) and water is constantly decreasing. No wetness on the passenger or driver side. I wonder if there is a crack in the pipes?
