About carbon clean
08.05.2020 14:04 # 1
ErkanKurnaz
yes aga, again me and again a question. what is this carbon clean? Is there any obvious benefit or harm to the vehicle to do this?
08.05.2020 14:04 # 2
don't worry you will get the answer as soon as possible;)
tomorrow sticker will be at hand today i have cargo i get your information :)
emrah 2009-07-13 23:21:47
08.05.2020 14:04 # 3
ErkanKurnaz
thank you bro. I will take the photo as soon as possible.
08.05.2020 14:04 # 4
GokhaN
I know it is an application that allows the engine to run properly and renew. No harm 5 It is useful to have it done every 6 months. Even if there is a problem with the operation of the car, it can even level. But don't expect too much on your own.
08.05.2020 14:04 # 5
individual
injector cleaning
but depending on the situation it may or may not work
It is made for homogeneous and smooth spraying of injectors.
over time injectors can connect soot
to clean them
but more effective way to disassemble injectors and blow them with sound waves
Thus, crumbs are poured like kidney stones.
more effective way but more expensive
08.05.2020 14:04 # 6
hasimayaz
The fuel hose to the engine is removed, instead Fuel + solution is sent with the help of a special device 30 - 40 min. After the vehicle operates in this way, every part of the fuel that the fuel travels is cleaned. The only possible negative side effect is if your catalyst is in poor condition, you can take it completely. Though the floor. if it is so bad it will put water already very soon. In old black diesel dies, the injector was removed and recycled with special machines. Diesel pumps were used in the industry. But the injectors of the new generations are not suitable for this. Carbon Clean may be the logical choice due to its high workmanship in disassembling and cleaning.
hasimayaz 2009-07-14 09:41:47
