About Brake Fluid
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 208
08.05.2020 20:54 # 1
samet206
Hello friends, the hand brake light was flashing when I was looking, I waited for a while, there was no noticeable problem on the brakes. Sounds like it is soft, is there any possibility of making the air by opening the lid and adding oil?
08.05.2020 20:54 # 2
talip206
I do not think it will make air with adding. But there is a situation that brake fluid does not decrease to a halt, there is a definite leak. Have leaned under the vehicle and look at the interior of the wheels. Do not neglect I think
08.05.2020 20:54 # 3
samet206
Thank you for your answer. I did all the controls, the front brake parts were completely new, including the included hose. I did not have a rear brake because I put it on the computer, I did not open it when I had trouble.
08.05.2020 20:54 # 4
My brother, who usually misses from the rear brake centers, had happened to my 206 cars. Brake fluid has always been for your boot. Brake centers 40 TL flan
08.05.2020 20:54 # 5
x571
[QUOTE = samet206] Hello friends, the hand brake light was flashing while looking, I waited for a while, it did not improve, there was no problem on the brakes. It does not warn anymore. It feels like the brakes are softened. Is there any possibility of making the air by opening the cover and adding oil?
it may happen if it gets very low and air enters the system If you lift it with a jack and get the brake air of a wheel, you will know. If it softened, there is a shortage.
08.05.2020 20:54 # 6
samet206
[QUOTE = x571] [QUOTE = samet206] Hello friends, the hand brake light was blinking while I was cruising, I waited a while, it did not improve, there was no problem on the brakes. I checked the hydraulic oil, the oil was at the bottom of the container. I couldn't fill them all up. The light went out no longer gives a warning. Looks like the brakes are soft. Is there any possibility of opening the cover and adding air by adding oil?
Thanks for your answer, it was not completely finished, but it was so little to say that I added it on and off. During this time, I was curious about the possibility of making the system air. The brakes are not enthusiastic about the hydraulic renewal and bleeding works. Obviously, if there is a place, I will handle it.
08.05.2020 20:54 # 7
samet206
[QUOTE = sonerkyl] often kidnapped from the rear brake centers, my brother had happened to my 206 cars. Brake fluid has always been for your boot. Brake centers 40 tl flap pieces [/ QUOTE]
Thanks for your answer. As you said in full, when cleaning and lifting the car, it turned out that there was oil leaking behind the left rear drum. The brake centers will change.
08.05.2020 20:54 # 8
talip206
[QUOTE = samet206] [QUOTE = sonerkyl] often kidnapped from the rear brake centers, my brother had happened to my 206 cars. Brake fluid has always been for your boot. Brake centers 40 tl flap pieces [/ QUOTE]
I think you can recommend a reliable master who will take care of these jobs in Üsküdar.
08.05.2020 20:54 # 9
x571
[QUOTE = samet206] [QUOTE = x571] [QUOTE = samet206] Hello friends, the hand brake light was flashing while I was looking, I waited for a while, there was no noticeable problem in the brakes. I checked the hydraulic oil, the oil was at the bottom of the oil. I bought 0.5 liters of DOT4. 250 ml I added it up to the brim it was full, I couldn't fill it all. The light went out no longer warning, it feels like the brakes are soft. Is there any possibility of opening the cover and adding air by adding oil?
you can't get it done. guys are not infected.
08.05.2020 20:54 # 10
samet206
It is not Istanbul, but for your attention, we have done the operation, something like we got the brake air with the master. 100 TL of workmanship was not a problem. Alone, the price was 450 TL for these transactions. I want to go where people are used to, but unless something is familiar, I would say it is useful to travel.
