about bosch spark plug 4 !!!
08.05.2020 13:57 # 1
beddri
slm
I have used bosch's 4-pin spark plug in hyundai before and I am happy now I want to use it in my car with pejo 206 1.6 16v. and I would appreciate if there are friends who wear it and use it.
Thanks to everyone who helped ...
08.05.2020 13:57 # 2
sinan-s
If it has 4 nails, it should fit
08.05.2020 13:57 # 3
[QUOTE = sinan-s] Should match if it has 4 claws [/ QUOTE]
no matter where you know,
08.05.2020 13:57 # 4
I think you can not get any efficiency ... I think it is a vehicle with an ignition mechanism that is not designed for 4 nail plugs ...
08.05.2020 13:57 # 5
beddri
I guess there is not much information about this :(
08.05.2020 13:57 # 6
Always Original Spark Plug.
If Bosh burns less or fires better, the fuel consumption will decrease. The factory already puts itself in the vehicle.
Let's not be surprised by the original spark plug.
08.05.2020 13:57 # 7
beddri
obviously I asked about the spark plug of bosch, not about the spark plugs that the factory had installed.
there are friends who know about it and I would be glad if they comment
08.05.2020 13:57 # 8
hasimayaz
More nail increases the number of hops, but the quality of the hops will be reduced. ignition must be supported by the induction coil.
In the old distributor engines, the coil was replaced and parallel to each other was installed in parallel, and the ignition was strengthened by using the double-clawed spark plug. It should not be forgotten that quality spark plug cables that will support such a high voltage.
However, doing this much ignition change in a vehicle with an ECU system can cause serious damage. As a result, you should not get much performance on multi-claw plugs on vehicles with Ecu system. On the contrary, you may even lose performance.
hasimayaz 2008-10-04 19:45:13
08.05.2020 13:57 # 9
beddri
Thank you very much for the enlightening and really useful information you provided.
08.05.2020 13:57 # 10
[QUOTE = beddri] obviously I asked about the spark plug of the bosch, not about the spark plugs that the factory had installed.
[QUOTE = beddr a] slm
I gave my own information and comment, if you read well my answer. Compared with the original spark plug in the review, I already told you that the factory would be trapped.
