ABOUT ATIKER SEQUENTIAL SYSTEM?
08.05.2020 14:06 # 1
fatih1903
friends I (307 xr 1.6 triptonic) decided to have my vehicle installed. Actually, I say I decided on money because now I want Simit lpg 1.000 TL tartar (1.750) or BRC (1.600).
But according to the very expensive atikeri, the master of the tartarini will have problems with your vehicle's automatic take-offs. ok I know that the traction will drop a little, I don't mind it. 1.6 cars pulls up, the bidet climbs like a peugeot so goat.
NOTE: when commenting, please do not think that you have tartar, I think do not comment like brc.
I EXPECT COMMENTS FROM EFE AND HASIM THANK YOU ...
08.05.2020 14:06 # 2
haruncoskun
3 months ago I had a tomasetto, I researched a lot before I installed it.
08.05.2020 14:06 # 3
Ragnarok
I have a manual gear 1.6 206XS. I had a Romano sequential system, but I have had no problems until now. Traction is falling but, as you said, 1.6 engine doesn't matter. I think the vehicle is still running well. I have never heard of the problem of stopping and never experienced. The only problem is that it jumps a bit more than when it runs on gasoline when the vehicle is stationary. So be it now :)
08.05.2020 14:06 # 4
fatih1903
[QUOTE = haruncoskun] I had a tomasetto 3 months ago, I researched it very much before installing it, I recommend you to research both the price is affordable and I am very satisfied, meanwhile, my car is 1.4 auto honda [/ QUOTE]
I have researched tomasetto a little, there is no company that wears a caramel, but everyone who uses it is now satisfied, I called one company, they said that we are just attaching the tartar to the peugeot car.
CAN IT BE ATTENDED TO THE SUBJECT OF ATTACHERS?
08.05.2020 14:06 # 5
Onur
sometime I thought I would have lpg installed in my car 206 1.4 automatic I searched a lot. they suggested only 2 brands, peugeot authorized service atiker and prins. They said they will not have the slightest problem in prins, they also assured you that they are also compatible with prins cng and the price is a bit high for the transition from lpg to cng in the future.
08.05.2020 14:06 # 6
hasimayaz
Atikers cause trouble in cold weather in Peugeot. He kicks until the car gets hot. No matter how much Atiker got, I heard the same trouble from all of them.
08.05.2020 14:06 # 7
<bugra>
the master says the truth. I have an atiker too;
especially working in gasoline until it gets warm in winter, the first 5 minutes when it passes to gas. can misfire. You can minimize the problem by putting an antifreeze ...
When it comes to the misfire problem, I think it is completely with the gas adjustment, after 2 months after installing it, the problem of misfire was solved in the traction, the fuel increased from 150 krş to 160 ...
2009-11-08 10:35:20
08.05.2020 14:06 # 8
fatih1903
Hello friends, as of Saturday, I am now approaching the pump that writes autogas at gas stations. I have trouble riding right now I have no complaints allaha thank you for the comments good day friends .... :)
08.05.2020 14:06 # 9
good luck master :) let's get it wet, let me gas it off hee: P: P: P
I make 95-100 km with 20 TL and I have to use it in normal use 80-90: p
08.05.2020 14:06 # 10
Murat
Good luck, Fatih.
I hope it will not cause any trouble. Safe and sound.
08.05.2020 14:06 # 11
Ragnarok
If I go below 100 km distance with 20tl gas, I count myself at loss :) It is super when I make 400 km with 60tl on the long road.
08.05.2020 14:06 # 12
FTH
Good luck with your wishes to ride smoothly ...
08.05.2020 14:06 # 13
fatih1903
thank you friends, by the way, the vehicle has been used as always as it was performed 105 km in the city.
08.05.2020 14:06 # 14
Onur
I hope you use it without problems Smile
08.05.2020 14:06 # 15
ErkanKurnaz
good luck Fatih good bye hopefully
08.05.2020 14:06 # 16
the only problem is master ........
The one who has a good master will have a little trouble.
08.05.2020 14:06 # 17
HELLO TO EVERYONE.......
I TARIK from ANKARA
I sold my 93 model falcons and I came across you by buying 307 XR 1.6 BVA triptronic. As soon as I became a member of the subject, when I saw the subject about the atiker, I said I should write. I just got ATIKER. and at the end of the 2-week trial period, I say ATIKER ... there was no LPG when I bought the vehicle. I am satisfied with ATIKER. I advise.
08.05.2020 14:06 # 18
fourus_06
about two years ago, I chose this system because we had no money at the attic system in peugeot service. Injectors were disposed of before any kind of infamous system did 30000km. etc. I think it will upset you that you have an atiker.
08.05.2020 14:06 # 19
fatih1903
Walla, do not be afraid if you trust this master, my master!
08.05.2020 14:06 # 20
yigit1989
as a result i have a question i have 307 automatic gearbox what do you suggest as a brand
Page : / 2
