About Angel Eye Far
08.05.2020 14:06 # 1
Ragnarok
First of all greetings. I still couldn't sell my car. I think it will not be sold in a long time. But since the day I posted it, I have been in and out of the forum very often, and I have learned a lot not only about peugeot but also about cars. Therefore, I would like to thank all the friends who wrote in the forum.
About angel headlights I want to ask. My car is 206XS, for example, when I buy an angel headlight, will it come out empty? Or will they have light bulbs inside? I look at the second hand as if it is empty. But in some places that sell zero, they say there are H1 bulbs. Is my head confused in every zamazingos when angel takes the headlights and stops? Or will we buy it in a bulb later?
Do we have to buy xenon when I get angel headlights? For example, can we wear the bulbs that we use normally? (For me it is enough to look beautiful during the day, there is no rule that it will be white light)
If I bombed, let me ask the last question, would you recommend angel? I read an article on the forum saying that there is no height adjustment on the angels. Is it true? Will the height adjustment button on the left go past my idle status?
08.05.2020 14:06 # 2
GokhaN
Besides angel headlights, they usually give yellow bulbs, depending on where you get it, there is no need for anything extra in the led stop. When Angel gets headlights, you don't have to buy xenon headlights, but you better. I do not know how many original 206 bulbs H, but you can attach to H1.
I recommend Angel, you can buy junyan, the motor is mounted directly, you can adjust the height like the original.
08.05.2020 14:06 # 3
Ragnarok
No need for bulbs other than leds at the rear stops?
Is it possible to adjust the height of angels other than Junyan? I think junyan is more expensive than others.
08.05.2020 14:06 # 4
GokhaN
[QUOTE = -Aazazel-] Isn't there a need for bulbs other than leds at the rear stops?
There is no need for bulb fln on the name of led stop, you can directly disassemble the water tank and even install it yourself. After the person who wears Junyan can adjust the two equally, you can adjust the height yourself. I don't know much about the price, but junyan is good. I used my old vehicle 106 for 1 and a half years without any problems.
08.05.2020 14:06 # 5
hasimayaz
I http://forum.peugeotturkey.com/forum_posts.asp?tıd=6512&title=206-gti-angle-eye-taktrmak-istiy
08.05.2020 14:06 # 6
Ragnarok
Thanks for the answers. It is best to think a little more. The lack of adjustment frightened my eyes. I think I need to look at a little bit of a type of junia that can be vertical. If there is a place I can find can you help? I am in Istanbul if peugeote helped, let me stop at the weekend.
08.05.2020 14:06 # 7
master
[QUOTE = -Aazazel-] Thanks for the answers. It is best to think a little more. The lack of adjustment frightened my eyes. I think I need to look at a little bit of a type of junia that can be vertical. If there is a place I can find can you help? I am in Istanbul if peugeote helped, let me stop at the weekend. [/ QUOTE]
It helps, but Efe also has a piece of origin.
I do not think it is an art or angel far, but I would say consult anyway ..
08.05.2020 14:06 # 8
asil 206
I bought yesterday, angel zenon plips white light bulbs in length, very sweet, lonely settings are very bad, they illuminate right and left. When I say making a setting, I broke the adjustment screw ...
08.05.2020 14:06 # 9
Ragnarok
Can I ask which brand of angel are you buying? Where do you make your settings?
08.05.2020 14:06 # 10
asil 206
julyan brand, the headlight plastic looks like a white-colored nut, a screw passes through it, and right-left adjustments are made when you turn the screw.
