About Adblue
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Other Brands
08.05.2020 20:07 # 1
Ramsey28
Hello friends
My car 308's relative C4 bluehdi confort
The other day, I gave the vehicle engine failure and the air pollution prevention system error after it and got the vehicle serviced. We looked at the service adblue tank was broken, the vehicle was guaranteed. We ordered the tanin, use the vehicle in this way, he said. I said how to break down every adblue, whether the tank changes, I said what to do when the warranty is over, they didn't say anything, they said use it until the tank comes. I am using the vehicle now but the vehicle is not malfunctioning yet. I think they deleted the errors from the computer, but even if the errors were deleted, should the tank fail, shouldn't the car still fail? Plus I think this vehicle is foreign to service. Now, when the adblue tank arrives, I should replace it or let me say it does not give any error, or the service couldn't do this adblue or something, did it break the adblue tank or something?
All comes to mind, what should I do?
08.05.2020 20:07 # 2
First of all, it is hard to break it while putting welcome edblue, so you didn't miss anything, and then if a strange situation is going to change from garnish, change it can happen again after two or three days. Probably for this problem, it is probably not giving fault code right now when edblue is over and it goes out and errors are deleted.
08.05.2020 20:07 # 3
Ramsey28
When they came from the service, they would not call yet. Thanks for the answer.
08.05.2020 20:07 # 4
You're welcome. I follow my teacher, if you write the result here, I will be served.
08.05.2020 20:07 # 5
Ramsey28
Hodja, as of yesterday, the tank came and they went and they took it. I said, how did this plastic tank break down? They said to me that there is an engine on the tank and the engine is not sold separately. I asked the replacing master, so I said, I came here, the fault was understood, then the tankin order was ordered, and you said use the tool like that until you came, you deleted the fault, you completed the adblue, then it did not make a mistake, I said that there is no need to replace it, it did not fail in a short time, but then it said.
I understood that they put air in the engine when putting on adblue in time, the bidet did not fill the tank completely, a week later they ordered the tank when it failed and there was no guarantee that there was a guarantee. In short, the service found a way to make money.
Bid, this is the sound of the creaking clicks of the front console of the car, as the screws are not tightened, when it is going on the stabilized road or the paved roads on the paved roads, the propeller whirling the front console of the propeller, the propeller sounding like a carpentomus, I was going to hit the car in the morning from my nerves. .
08.05.2020 20:07 # 6
OguzhanKucuk61
No sound, sir :) I am exploring a new whirlwind center every day. I'm walking around as if it is full. The buzz is not only on bad grounds, but also when the cycle is low. We tolerate it in such a way :)) I don't like it at all. However, although your vehicle is a new model, it annoys as it does so. I recommend silicone spray. May Allah make it easy ..
08.05.2020 20:07 # 7
Ramsey28
Thank you for your interest, healthy driving.
08.05.2020 20:07 # 8
I'm glad your problem is solved, hodja. My father-in-law has a c4 cactus, there is a tenth, there was a sizzle, it was coming from the ventilation ducts.
