About 406
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 406
08.05.2020 14:05 # 1
tugrabozan
I have a little damaged service document about 406, I have friends who want to share their problems as I did not dismantle
08.05.2020 14:05 # 2
selenge
There are 98 models 406 m ..philips cd changer has a problem and there is no master who understands from work ... i want to be master .. if there is any document about how to disassemble it, how to fix the fault ... NO DISK warning every time.
08.05.2020 14:05 # 3
rifatseker
If there is no other problem,
In general, if there is No Disk warning, there is a small potentiometer next to the laser eye in the device which has many laser readers that are likely to be laser sight. It is a potentiometer similar to the picture below. If you play with this setting, you may be able to read the discs if it is still intact by making minor changes in the perception of the laser.
Good luck with.
08.05.2020 14:05 # 4
selenge
Well, if that laser eye is not solid, can it be changed, how can we fix it, is it possible to repair it without professional help?
08.05.2020 14:05 # 5
rifatseker
If that laser eye is defective, there is not much to do, at least if something like the part number can be found around the eye, maybe you can find the opportunity to obtain it from electronic parts sites, not at home but abroad.
But replacement work must be in the hands of the master, because there may be situations that require fine workmanship.
Good luck with.
08.05.2020 14:05 # 6
tugrabozan
Maybe I was overlooked, I think there might be a possibility to put the CDs upside down. Sırıtma
08.05.2020 14:05 # 7
selenge
Embarrassed I haven't tried it, but .. the problem is not there .. I will go into the potentiometer event anyway, I hope it will be or I will get a tape.
08.05.2020 14:05 # 8
mcnyz
Hello everyone, good night Ouch I have the same problem with the cd player in my 406 3.0 sv vehicle.
