About 307 im
08.05.2020 18:46 # 1
cnrars
Guys, how many speeds did you last with the 307?
I think there is a problem with mine, the problem is either in the tires or in the front row, but there is a problem. After 110, the car goes left and right as if there is a lot of wind, balance and tie adjustment are needed, there is tremor, but this problem has existed before, why can this be? Original wheels on my wheels, my tires are 15 petlas, in original sizes ,
The other issue is that when the brake presses (at slow speeds) the fedal is going in too much and the abs is working at the slightest brakes, and when the abs is not engaged, the car is bouncing, my pads are new, my discs are in good condition, I bought my tires in March this year.
08.05.2020 18:46 # 2
tongucuk
Have a good tie-bar balance adjustment, check the front set of the master, the wires inside the tire may be broken (if you are sure that you have zero the tires you are using), check the tire pressures, if all the controls are achieved, when the vehicle touches the brake when it touches the brake while traveling fast and fast. sorry that there may be a play in the chassis of the vehicle
Also, if your car's engine does not have a turbo problem, you can easily see 190, but do not speed up, go 15 minutes late to your destination.
08.05.2020 18:46 # 3
cnrars
Thank you for your answer, I made the rot and balance adjustment today, my uncle tire guy said that the tires are very bad, many people who take petlas have similar problems .. My tires are making a lot of noise, making a soggy sound, now the tremor in the steering wheel, but I think I need to buy a tire ,
i bought the tires like march last year, i made almost 20 thousand km, my car has no accident :( don't scare me call chasis
08.05.2020 18:46 # 4
Efe-Pojo
You have said that I thought your car was not a 307 but a Taurus, I think it's not as pessimistic as you think.
08.05.2020 18:46 # 5
cnrars
[QUOTE = Efe-Pöjo] you have said that I thought your car was not a 307 but a Taurus, I think it is not as pessimistic as you think. [/ QUOTE]
let's see rot and balance adjustment, I went in the evening traffic, there was no way to accelerate, I could not exceed 30km in the same way in the morning :) I will test it at noon, but the tire tire is very steep, michelin said that if I buy tires like continental, these complaints will not be any of them. So I advertised to sell my tires, I will buy 16 rims, a little wide base tire I think it provides better handling, fuel will notice a little ..
If you are interested
http://www.sahibinden.com/ilan/yedek-parca-aksesuar-donanim-tuning-jant-lastik-jant-lastik-takimlari-peugeot-307-308-207-208-195x65x15-jant-ve-lastik- team-177772917 / detail
08.05.2020 18:46 # 6
307 afyon
190 KM AFYON KÜTAHYA I RECEIVED IT IN 32 MINUTES DAY 2 OF THE HOLIDAY MORNING 6.00 THE ROAD WAS EMPTY AND THE DUBLE WAS NEW.
08.05.2020 18:46 # 7
ahmetemir
[QUOTE = 307 opium] 190 KM AFYON KÜTAHYA I RECEIVED 32 MINUTES DAY 2 DAY OF THE HOLIDAY 6.00 THE ROAD WAS EMPTY AND THE DUBLE WAS NEWLY MADE ON THE ROAD ONLY 2 CARS. [/ QUOTE]
I hope you paid attention to eds and I was entering it too, thanks for sending it behind me :)
