About 307 HDI Spark Plugs !!!
08.05.2020 14:56 # 1
dbmaster
Greetings to all, I will have a question about an issue that I do not know about, friends, I do not know when I bought the car in April, I will experience the first winter season with HDI.
The vehicle has a 2006 model 1.6 110 HP version, but although it drops to 14 degrees in the air, the lamp of the glow plugs does not light in the first start yet how long will this light be on?
Respects
08.05.2020 14:56 # 2
karacocuk
What is the lamp you mean by the glow plug, when the ignition is switched on, the engine light burns and turns off when there is no malfunction.
08.05.2020 14:56 # 3
dbmaster
Just like you said, the lamps are on, then it ends. When you leave the car, there is no error lamp, but there is one more lamp.
08.05.2020 14:56 # 4
Onur
What was the heating spark plug, not the gasoline? If the normal spark plug has expired, it may burn the lamp and it will not be related to cold.
08.05.2020 14:56 # 5
Onur
pardon you have written hdi in the title, I did not see it. The glow bar is his lamp is lit, is it a spring lamp?
08.05.2020 14:56 # 6
dbmaster
[QUOTE = Honor] sorry you wrote hdi in the title, I did not see. the superheater bar is its lamp lit up, is it a spring lamp? [/ QUOTE]
I am wondering that the lamp in the shape of this spring will not burn even though the weather is 14 degrees.
08.05.2020 14:56 # 7
Onur
preheating means its burning in degrees I do not know it is better not to burn in cold Gülme
08.05.2020 14:56 # 8
dbmaster
Of course, it was better not to burn, I just wondered about the thing.
08.05.2020 14:56 # 9
kabus
[QUOTE = dbmaster] [QUOTE = Honor] sorry you have written hdi in the title, I have not seen. the superheater bar is its lamp lit up, is it a spring lamp? [/ QUOTE]
When my friend turns the first contact, you are talking about the glow plug light, before the vehicle starts, I think that there is an abnormality in the shape of the arc that lights up after 14 degrees in the air.
the other one is hyundai when i turn the first contact on both of them, the glow light light is on in both vehicles, moreover our air here is 3-4 degrees warmer
08.05.2020 14:56 # 10
dogu
I have 1.6 90 hp 2006 307 too. I haven't seen that spring lamp come on since 2006
08.05.2020 14:56 # 11
furkan
every diesel vehicle has no bow light, there is no stop, some indicators have the light you say in some indicators
08.05.2020 14:56 # 12
Aytac
The Spark Plug Lamp Lights Up At Every Contact Of The Ignition Will Turn On Later ... If It Is Not On, The Failure May Occur In One Or All ..;)
08.05.2020 14:56 # 13
peugeot murat
friends, peugeot researches that came out after 2002 is equipped with the electrical heritage that we call as multiplex 307, neither oil nor heating lamp lights up even if the oil lamp stops in case of malfunction. if it doesn't work call your service
08.05.2020 14:56 # 14
my.ozkara
Hello friends. I have the 2005 model 307 1.4HDI. When I turn the ignition, the lights go out after a while, but after a while, the stop lamp lights up and the screen shows "top up cooltant level". It continues this way until it goes. Do you think it has anything to do with the glow plug?
08.05.2020 14:56 # 15
[QUOTE = my.ozkara] hello guys. I have the 2005 model 307 1.4HDI. After turning the ignition, the lights go out after a while but after a while the stop lamp lights up and the screen shows "top up cooltant level". It gives the warning. And it never ends until it goes to the bio.It has anything to do with the glow plug? [/ QUOTE]
"Add low water level," he says. There is a place like a ball when you open the hood, as in the picture below. There are max and min points on it. Open the lid and check. Complete if missing but not with normal mains water. It would be better if you complement it with antifreeze. If you have not changed your antifreeze for 2 years, it will cause you to change the antifreeze water of your complete vehicle and it will not take much money.
PS: As every member does, you need to introduce yourself under the relevant title. Normally unrepresented members are not answered, but this time between us, no one can hear Embarrassed
Koliva 2011-01-13 16:26:21
08.05.2020 14:56 # 16
my.ozkara
hello. I did not know because i am a new member of the forum. i did what you wanted but the level is min. with max. It has already been 3 months since then. Let me ask the old owner, then. How would we make the promotion?
08.05.2020 14:56 # 17
[QUOTE = my.ozkara] hello.I did not know because i was a new member of the forum. I did what you wanted but the level is min. with max. in between. It has been 3 months since I have asked the old owner.
In the general part, there is a part of getting to know our Members. Fill out the form below and send it there.
1.- Your name and surname:
2.- Your age:
3.- Your vehicle (Brand, model):
4.- Your hobbies:
5.- Your profession:
6.- Where did you hear the site:
7.- Your Blood Group:
8.- Your horoscope:
9.- The team you support:
10.- Which county or province are you in:
11.- Your MSN address:
The problem is perhaps from the sensor.
08.05.2020 14:56 # 18
oguzhan29
As you say brother, it burns in very cold weather - the air that will fall down to you but the air in your location is hard at 14 degrees a little bit of bidet.
