About 307 failure
08.05.2020 16:26 # 1
barans
hello friends
& nbsp;
started to stop eating gas on my vehicle tonight and the engine noise changed.100 km speed does not exceed. There is no traction and I am outside the province, would you mind if I continue this way? help please !!!!
& nbsp;
& nbsp;
& nbsp;
08.05.2020 16:26 # 2
felusdomesticus
ice alert is not a fault message, it warns that there is a risk of icing because the weather is cold, other than that, I don't know the other issue
08.05.2020 16:26 # 3
hsnsnr
What is the vehicle 307 diesel petrol 1.4 or 1.6 ...
08.05.2020 16:26 # 4
sedataksu
Could there be a problem with your fuel.
08.05.2020 16:26 # 5
barans
307 gasoline + lpg 1.6
& nbsp;
thanks
08.05.2020 16:26 # 6
spilmac
My brother had the problem either in the catalytic convector, in the spark plug, in the coil, or in the valves ... I had the same problem.
08.05.2020 16:26 # 7
erkerd5429
I think the problem is in the engine :))))
08.05.2020 16:26 # 8
[QUOTE = spilmac] My brother had the problem either in the catalytic convector, in the spark plug, in the coil or in the valves .. I had the same problem. [/ QUOTE]
Absolutely Right. My friend, who had the same problem at Mitshubishi Carisma, said the service said these problems but his was in the coils.
08.05.2020 16:26 # 9
ByHack
& nbsp;
is probably due to the above reasons; + Let's add the air filter and fuel (lpg-gasoline) filters :)
08.05.2020 16:26 # 10
simirnoffredbull
I had the same problem, I had a problem with the injector. they have a special machine that they plug in and clean to the machine .. I did not pass 4 thousand cycles .. now they were skeptical of the catalytic convector like a car monster, but the injector is out .. but you can still connect it to the machine
