About 307 electrical components;
08.05.2020 17:17 # 1
sercan1903
"C & nbsp; Hello friends;
I needed your help with my electrical component problem that occurred yesterday on my Peugeot 307. I parked the car normally and closed it, and then when I wanted to open the car after a couple of hours, I noticed that my immobilaser switch was not working. I opened the door with the key, but when I inserted the key in the ignition, I saw that there was no electricity in the system at all. DIV> I couldn't get out of the job, I would be glad if you help,
Thank you ...
& nbsp;
08.05.2020 17:17 # 2
hsnsnl
the batteries are self-evident, it is necessary to try with a supplement with another vehicle, or if you have a battery :)
08.05.2020 17:17 # 3
fatihgg
exactly how is the battery?
08.05.2020 17:17 # 4
xMEGANx
ahaha: Dbi key's battery is out of battery: D
08.05.2020 17:17 # 5
Serkan
Even if the battery of the key is not installed, it will not only open the doors with the remote control, but everything works normally in the vehicle. In addition, when the battery is low, the screen gives a low battery warning. Your friend's problem is not related to the key battery.
Serco05 2013-01-14 15:56:48
08.05.2020 17:17 # 6
xMEGANx
[QUOTE = Serco05] Even if the key's battery is not installed, it does not only open the doors with the remote control, but everything works normally in the car. In addition, when the battery is low, the screen gives a low battery warning. Your friend's problem is not related to the key battery.
I think the system may have locked itself. Hacker mod like ten
08.05.2020 17:17 # 7
Serkan
[QUOTE = xMEGANx] [QUOTE = Serco05] Even if the battery of the key is not installed, it does not only open the doors with the remote control, but everything works normally in the vehicle. In addition, when the battery is low, the screen gives a low battery warning. Your friend's problem is not related to the key battery.
If you want you can remove the battery from the battery and try it out, the spare keys are already without batteries, with a remote control, I run the vehicle with a battery and dead battery.
08.05.2020 17:17 # 8
tellotello
It sounded like a battery problem to me. It can show itself especially in winter, as your friend said at the top. What is the condition of the battery, when did it change? Have a check done.
08.05.2020 17:17 # 9
sercan1903
friends I just bought the car. It's been about 2 weeks. the battery is probably not very good, but isn't it strange that there is no electricity to a hitch? You turn the ignition, but there is no electricity in the vehicle. No lamps are lit, no exaggeration.
08.05.2020 17:17 # 10
xMEGANx
[QUOTE = Serco05] [QUOTE = xMEGANx] [QUOTE = Serco05] Even if the key's battery is not installed, it will not only open the doors with the remote control, but everything works normally in the vehicle. In addition, when the battery is low, the screen gives a low battery warning. Your friend's problem is not related to the key battery.
If you want you can remove the battery from the battery and try it, the spare keys are already without the battery, with the remote control, I run the vehicle with the battery and the exhausted battery.
Then I will not know, teacher, I do not have much experience in this matter before.
08.05.2020 17:17 # 11
EnSoNiQ
the same battery that has happened to me, I changed the battery, there is no problem, the third day I bought now, if you bought a car from the gallery, they usually separate the solid batteries for themselves :)
08.05.2020 17:17 # 12
The lack of electricity in the system indicates the battery. Could you forget the headlights or other electronic devices?
08.05.2020 17:17 # 13
sercan1903
Thank you very much for your attention to the friends. The problem is due to the battery. I changed it and the problem has been solved.
08.05.2020 17:17 # 14
metegorkem
The immobilizer is not affected by the battery. The lights will come on even if the immobilizer fails or if you insert a key without an immobilizer chip and turn the ignition. electricity will come. the starter will even start when you turn the ignition, but the vehicle will not start. you definitely have a problem with the battery.
edit: I would say that even if the problem is solved, your eyes are bright. & nbsp; "Smile"
metegorkem 2013-01-15 14:36:24
08.05.2020 17:17 # 15
sercan1903
"Smile" & nbsp; Yes, thank God it was solved, but thank you to wool.
08.05.2020 17:17 # 16
sercan1903
sorry i was going to write anyway ... dearness of the keyboard buddy ... :)
