About 307 Digital air conditioner
08.05.2020 16:25 # 1
bestfear
Friends slm ... The digital display does not hold directions ... for example, I just put the heat down, but it does not happen ... & nbsp; & nbsp; & nbsp;
There is also this outside bleed button & nbsp; ... when we press this button, when the sign appears on the screen, does it take the air it gives inside the car from outside, or is it the opposite ...
08.05.2020 16:25 # 2
lkr_yldz
When that sign appears, it cuts off the air coming from outside, just turning the air inside.
08.05.2020 16:25 # 3
gozem
[QUOTE = lkr_yldz]
when that sign appears, it cuts off the outside air only turns the inside air vehicle [/ QUOTE]
08.05.2020 16:25 # 4
bestfear
Ok. & Nbsp; Thank you ... in what situations should we operate ...
What could be the reason for the air distribution setting to work erratically?
08.05.2020 16:25 # 5
mon
If I say problem in my 206, this problem exists. Mine is analog air conditioner, I am giving the air to the feet but it comes from the front console. I think there are other pejos too. & nbsp;
08.05.2020 16:25 # 6
mehmet_2
2006 1.6 hdi 307 my car has the same problem, the air steering button does not work, it always blows into the car and does not give it to the feet and pines. We are waiting for help from those who can solve or have knowledge
08.05.2020 16:25 # 7
ByHack
Friends, if you say the problem is uneven air blowing, you have not paid any attention to other cars (except bidirectional ways) If you are blowing air everywhere, there is no problem. Besides, when you give the air to the foot part, & nbsp; I saw the coming of air in every car. The friend has the 2011 corolla, the 2011 focus is the same. When you give the air to the foot part, it comes to your forehead. Moreover, the air conditioner of the 307s is really good, whether in heating and cooling, or in balanced dispersion. The problem is okay if it blows air everywhere when you take it automatically, then it blows air to the point you set later. But whatever I do, if you say the problem is always the same, it shows the master to show it to a master.
08.05.2020 16:25 # 8
mehmet_2
yes, no matter what you do, it blows to the same point. I showed it to the master, he said it was from the engine.
08.05.2020 16:25 # 9
ismail ozdemir
wherever I give it in my car, it goes there, feet upright to the chest, up to the chest in the up position on the chest above the chest, the front resistant sign gives the windows to me I don't have a problem.
08.05.2020 16:25 # 10
ByHack
[QUOTE = ismail özdemir] wherever I put it in my car, it goes to the feet in the perpendicular position on the chest, in the upward position on the chest, the front resistant sign on the windows, I don't have a problem, I think your vehicles have a breakdown [/ QUOTE]
< / DIV> & nbsp;
I don't think there is a malfunction in my vehicle either. When you direct it to the foot side, hot air comes from the air ducts in the dashboard even if it is a little. I have stated that I did not encounter the two-way air conditioners in many vehicles that I got on, there is this event. I even throw the air conditioner off when you are at 28 degrees, while going at high speed, the air channel that you used to turn the air conditioner off before turning off the air conditioner comes with a little bit of hot air. If it does not come, if you press the button where you cut off the outdoor air, your windows will be steamed. Try carefully you will see ...
08.05.2020 16:25 # 11
ByHack
[QUOTE = mehmet_2] yes whatever you do blows to the same point. I showed it to the master, he said it was from the engine, he could not
& nbsp;
Being digital makes the air conditioner a bit difficult, unfortunately. There is no one we know in Aydin, let's give an address. Hopefully a friend with knowledge on the topic will help in the forum. Hello, brother, thank you ...
