About 307 abs
08.05.2020 17:36 # 1
kasirga16
hello friends, my 307 sw automatic gearbox sometimes draws the rear tires when the brakes are pressed, and when the brakes are loaded firmly, I get stressed that there will be no cuddling cuts, but there is a problem?
abs warning lamp does not light on the display
I would appreciate if you help
respect ..
08.05.2020 17:36 # 2
Serkan
Sir, that crackling noise comes out because ABS is activated, when ABS is activated, the light does not light on the display, the ABS light turns on when there is a malfunction in the ABS system. So it's okay
08.05.2020 17:36 # 3
eeccaa
If the tires that you call scratching leave traces on the ground, even though ABS works normally, the tire trail may remain on the asphalt sometimes. Because cut-out and short tires on the basis of cm are actually slipping. We see the combination of those tracks. But the front is leaving a mark. Because the pressure on the ground is very low, especially in hard braking, and it seems like it is impossible for me to leave a trace behind and leave a trace. or if you suspect that it is braking stronger than the front, you will be knocked on the brake with a light steering movement, which is very dangerous. For this reason, I wanted to go over it. & Nbsp;
08.05.2020 17:36 # 4
kasirga16
friends, I was wondering if there is a problem in the abs system, the rear tires are drawn on dusty gravel ground especially when going down the slope. I want to emphasize this situation. Is there a problem with these tires, lining discs or abs system?
Greetings to all ..
08.05.2020 17:36 # 5
Bugra
to draw & nbsp; what do you mean, my teacher. a kind of voice or a trace I did not quite understand. & nbsp; bugrature 2013-05-20 09:29:58
08.05.2020 17:36 # 6
kasirga16
My teacher says tires are skidding, the rear tires are locked.
08.05.2020 17:36 # 7
Bugra
heh now understood. Now let me tell you the car brakes when the front tires are braking 75% and the rear tires will brake 25%. that is, the rear brakes less than the front (in the foot brake) if there is a difference in this ratio, that is, if the rear brakes more, what happens to it now is, and worse, when the vehicle brakes, the hello bends (when the bend bends the brake, in this case it does roll) show to a master I don't know my campaign disc brakes anymore ... & nbsp; bugrature 2013-05-20 09:29:34
08.05.2020 17:36 # 8
kasirga16
Thank you, teacher, thank you for sharing.
The maintenance had also come and the vehicle should be put in a complete check-up
08.05.2020 17:36 # 9
eeccaa
[QUOTE = bugrature] rear brakes less than front (at foot brake) & nbsp; [/ QUOTE]
Exactly . The front-rear weight distributions of the front and rear-wheel drive (that is, the majority of cars in the middle) are about 70% to 60% front, 30-% 40% rear. Even when stationary, the front wheels carry most of the vehicle weight. As the center of gravity will slide forward in a vehicle that is effectively slowing down, the difference in front-rear load distribution increases even more. In fact, the rear disc and pad dimensions are designed much smaller than the ones on the front, however their service life is 3-4 times longer than those on the front. Even the worst, oldest technology vehicles have mechanisms that send the majority forward by lowering the pressure to the rear when braking. It seems that you are not working healthy. This will be resolved after brake maintenance, but don't delay the maintenance.
It is also thought-provoking that a sliding wheel is involved in a vehicle with ABS. When you turn on the ignition, your ABS lamp should be on for a few seconds without pressing the starter and then off. If this is the case, the system should be working normally, you already said that you heard the sound of the system. Because it is impossible for ABS to work on certain wheels but not on some. They are programmed to completely disable themselves in the slightest fault.
< span style = "line-height: 1.4;"> Even if you lower it fully, does your hand brake remain pulled a little? This can explain all the imbalance you are experiencing. & nbsp; Anyway, inform us when you solve it, get well :)
08.05.2020 17:36 # 10
kasirga16
Sir, thank you very much for your valuable information, I would like to have the brake maintenance of the vehicle checked and change the front and rear brake pads and brakes.
& nbsp; regards originally
08.05.2020 17:36 # 11
kasirga16
[QUOTE = hurricane16] front rear pads and brakes [/ QUOTE]
I would say pads and discs :)
08.05.2020 17:36 # 12
Bugra
The original brake assembly parts are sponsored by our forum. If you want a visit.
