About 306 Torsion Repair
21.06.2020 19:53 # 1
Alpbalturk
Hello friends. As I mentioned earlier, I suffer from torsion squeaking. My friend's father said that he could fix it himself because he was a turner, but because he was dealing with ships, not cars, he could do it if I could specifically tell him what to do. We had previously had a spacer built for him, someone who can do his job as long as he is shown with my friend. Now, my question for you is what exactly needs to be done to prevent our torsion from squeaking. Does anyone know about it? For example, the balls will change or the shaft will be turned and so on. Since I don't understand much about car suits, I was broke to describe. If you can help me, you will save me a good expense.
22.06.2020 01:59 # 2
talip206
I think this topic helps. If not, if you write torsion in the Search section, there were many repairs and images about it.https: //forum.peugeotturkey.com/forum_posts.asp? TID = 48849 & KW = Torsion & title = 206-torsion-and-bush-repair
30.09.2020 10:40 # 3
dfiratd
Hi; I don't know if the subject is closed, but I wanted to pass information. Normally the torsion has to be changed, but the deformation in the rear wheels was not too much. There was no gap in the wheel, but obviously the owner before me had loaded the vehicle. If there was a gap in the wheel or the sound of hitting in the holes, I would have to change it. I had 2 grease nipples installed on the long iron to which the torsion was attached. I do not exaggerate with an automatic grease machine, grease was pressed for 10 minutes. I gave a set price of 100 TL for grease and 60 TL for grease. The result is excellent. Let the squeak flow like oil on the road.
30.09.2020 17:37 # 4
talip206
How much workmanship did you give?
01.10.2020 10:23 # 5
dfiratd
[QUOTE = talip206] How much labor did you give? [/ QUOTE] Hello I have not paid any other charges. 100 + 60 total 160 TL. You have the turner drilled the holes and put the grease nipple, then go to a place that car washes lubrication and press grease, that's all. Grease nipple 3 TL
