About 206 Sagittarius
08.05.2020 19:15 # 1
samet206
Sa friends, I have 14 steel rims in my car, but I love it because I am satisfied with the overall shape, although I do not satisfy the image very much. - If I remove the original springs with a rim and install a 3.5 cm spring, I expect an answer from those who have information about how much the car is pressed or something does not change. to close the distance between the rubber fender, which seems not too clear.
08.05.2020 19:15 # 2
GokhaN
If you want to turn it off completely, I wouldn't recommend you need a spring shortcut or presslet. Coilover is the only solution.
If you say a little, the car's engine is light, so the car falls between 3.5 cm and 3.5 cm. If you wear 5 cm, it falls between 3 and 4.5 cm. you should make your own account, drop it as much as you want.
I will write an article about this spring talk Smile
08.05.2020 19:15 # 3
samet206
First of all, thanks for the answer, it is really useful when it comes to the article. 206s seem to be higher than those produced in the following years, especially since the rear bumper is not angular. For example, 4 fingers go between the fender tire and 2 fingers fall down to me. If I wear a 5 cm spring, 14 wheels seem to be buried with 65 sidewall tires.
08.05.2020 19:15 # 4
KuzuX
I have eibach 3.5cm. Comfort is zero.
08.05.2020 19:15 # 5
samet206
Do not say thank you for commenting, some do not even comfort, some do not press, even the vehicle does not descend. Eibach was not like that. .
08.05.2020 19:15 # 6
koray.turan
I did not cut it, I bought a direct spring and I am very pleased, very soft spring comfort, I cut the shock absorber balls, etc. etc. If you want, you can see and test it in my car if you want.
08.05.2020 19:15 # 7
koray.turan
Picture of Paylascam 5 spring two parnak 15 wheels
08.05.2020 19:15 # 8
samet206
[QUOTE = koray.turan] I did not cut it, I bought a bow directly and I am very satisfied, very soft spring comfort, I cut the shock absorber balls, etc. etc. If you want to come out, you can see and test it in my car [/ QUOTE]
Thank you for your interest, which brand of bows, how many cm bows did you choose?
08.05.2020 19:15 # 9
koray.turan
It should be Tunzero now I share the 5 spring
08.05.2020 19:15 # 10
koray.turan
08.05.2020 19:15 # 11
koray.turan
My Rims 15
08.05.2020 19:15 # 12
koray.turan
If you wear laguna lip, I am sure it will be very sweet, the photo is on the side :))
08.05.2020 19:15 # 13
samet206
Thanks for the suggestions, let me see your suggestions.
08.05.2020 19:15 # 14
koray.turan
Thank you
08.05.2020 19:15 # 15
koray.turan
When you say buffer heat?
08.05.2020 19:15 # 16
samet206
I told him in the sense that I think of the lip after somehow it did not match my foggy bumper.
