About 205-40-17 rims
08.05.2020 18:46 # 1
tolga.onal
Friends, I am replacing the rim-tires of the car, I bought sports springs, it is already in my hand. does it fit In short, what is the ideal sidewall size for these 307s on 17 wheels, I look at the internet, who is wearing 45, who is wearing 50, and which sidewall we use, we prevent the axles from getting more load?
08.05.2020 18:46 # 2
Barut
If the vehicle is 307, I heard that 215 45 17 is the most ideal.
08.05.2020 18:46 # 3
tolga.onal
http://www.sahibinden.com/ilan/yedek-parca-aksesuar-donanim-tuning-jant-lastik-jant-lastik-takimlari-peugeot-ford-uyumlu-17-inc-celik-jant-174656996/detay/
The wheels I intend to buy are these I have found a tire size calculator program 225-45-17 looks ideal, if I install them there is a 6% difference and the program says we do not recommend more than 3%. Does it cause a lot of trouble?
08.05.2020 18:47 # 4
Barut
I think 205 40 17 tires are incompatible at 307. This measure is the most ideal in 206. It is useful to wait for 307 users.
08.05.2020 18:47 # 5
BG307
Not 307 to 205/40/17. That measure is 206. You dismantle the front team with that tire.
It would be 225/45/17 or 205/50/17 to 307. Tire ex works 205/50/17.
08.05.2020 18:47 # 6
Mdeniz
my car 206 and its size 205-40-17 are perfectly matched enough but I think 45 45 cheeks are rubbing because 206 can be different in 307
08.05.2020 18:47 # 7
tolga.onal
Thank you, I gave up taking it to everyone I will pay attention to 205-50-17
08.05.2020 18:47 # 8
DgNTsN
215/45 R17 to 205/40 R17
The differences are:
base width 10 mm, ie 1 cm less
the tire is 3 cm narrower than the outer diameter, i.e. 1.5 cm narrower than the sidewall
For 205/40 R17 peugeot 206. makes rubbing over. the cheek is very thin and requires very careful use.
I think it doesn't cause trouble in 215/45 R17 307. It provides trouble-free driving.
Tires over 215 are very rough. worthy.
08.05.2020 18:47 # 9
tegote
You gave up but I'll write in general. I do not understand why those who say "I use it in front of 205 40 17 backs 215 40 17 307 are not satisfied" will not be the reason. No problem after falling into the deep hole or not entering the cornered places like sidewalk fast. I think 17 to 18 small 18 are ideal. If you want it to be more sporty, don't get a base below 215. Although 307 does not show much, the molded 205 base remains thin. One last note, you don't even understand the effect of fuel after buying a lighter rim. With these measures, my fuel is 22 cents per km. The price of the lpg is 2.55. The room had only bothered me once, and we had an average of 80 pounds each in the car, and they hit the back in the pits. other than that, I had no minor problems.
08.05.2020 18:47 # 10
tolga.onal
I decided on 225-45-17 and I got it, before the feast, I went to istanbul-konya 2 times before I came, I do not remember that I have been in bends like this before :) 225 base performance has lowered a little bit on departures but love is able to hold after acceleration :) Braking distance was very good. Frankly, I think that he did not lose much in comfort, just a little hardened.
There is something I want to ask for in the bidet. On these roads, the trucks usually settle down a bit of asphalt, or like that, when they go there, it seems as if the tire enters there and the steering wheel loses its dominance. I wonder if there is a problem
08.05.2020 18:47 # 11
kopiiilcan
I'm having the same problem. 205x40xr17
It is necessary to use polite. Ewet is on departures. And it requires a lot of attention to the corners. If you get new, you can distribute ten tapes to these bands and start riding polite on the field.
