About 106 gear changes
08.05.2020 17:21 # 1
volkanC2
In my 106 xr, 1st and 2nd gear shifts, it is a little harder to stop, it is a little harder to stop when I throw it to 1 and 2 when I want 2. There is no problem where I stand, but it goes smoothly to 1 and 2
08.05.2020 17:21 # 2
outlaw
There may be a problem with the gear gears 1 and 2, first look at the gearbox oil and if it does not go wrong, then it is in the gears.
08.05.2020 17:21 # 3
volkanC2
Can anyone help if anyone knows where to check the gearbox oil? Maybe I have to mix the forum now, but I am waiting for your help :) Check if it is a costly job.
08.05.2020 17:21 # 4
byx
unfortunately it is a bit costly gear work, the gearbox will be disassembled, the part replacement required to be disassembled, and it will be assembled and reinstalled. I bought gearbox oil 3 lt. old oil was drained, new oil was put in. I got out of the test, I did not understand that the gear is getting harder. I used patiently 1 week and 15 days and finally the gears started to pass very comfortably. : -) & nbsp; Makes the change in 10 minutes if you go to the master. get well soon.
08.05.2020 17:21 # 5
volkanC2
[QUOTE = byx]
unfortunately it is a bit expensive gear work, the gearbox will be disassembled and the parts to be disassembled will be assembled and re-assembled. I bought 75/80 total transmission oil 3 lt. old oil was drained, new oil was put in. I got out of the test, I did not understand that the gear is getting harder. I used patiently 1 week and 15 days and finally the gears started to pass very comfortably. : -) & nbsp; Makes the change in 10 minutes if you go to the master. Get well soon. By the way, I am sitting in Bahçelievler, I would like to meet you if there is a master you know.
08.05.2020 17:21 # 6
outlaw
You can't handle the gearbox oil, it's a detailed job that the left wheel is changing from there. outlaw 2013-02-13 12:51:24 < / edited>
08.05.2020 17:21 # 7
volkanC2
the master does it in 10 minutes, there is no need to tamper anyway:) & nbsp;
