Abnormal malfunction - fault recording
08.05.2020 21:26 # 1
samet2461
I wanted to attach cruise control to my vehicle and started to see different strange malfunctions. When I connect to the computer brain with the computer, I get the following errors;
—Caution: ECU 206 ME744 N6A NFU mounted on it
Then I login with enter, the following error comes;
- Install the appropriate ECU incompatible ECU (engine, system or vehicle incompatibility). Despite this brain allocation, would you like to continue diagnostics
I'm doing F3 and connecting
I am reading the engine Failure record;
- P0655 - non-referenced fault after sales.
What could be the reason ???
samet2461 2020-01-18 21:14:48
08.05.2020 21:26 # 2
omerb
Normally it says engine hot warning lamp etc. for this error code. Could there be a problem with your connection program?
08.05.2020 21:26 # 3
samet2461
[QUOTE = omerb] normally says engine hot warning lamp etc for this error code. Could there be a problem with your link program?
We tried it on 2 devices and 2 machines. One was the diagbox and the other was the peugeot planet office program. They both wrote the same. ECU not compatible error sounds strange
08.05.2020 21:26 # 4
samet2461
If I find out, it is enough if I find out that I can solve
I get the following errors when connecting to the motor brain
08.05.2020 21:26 # 5
I looked at the brake cables, my teacher must have 4 cables, but unfortunately before the 2005 307s there may be a problem, the engine cannot support the ECU.
08.05.2020 21:26 # 6
samet2461
[QUOTE = sonerkyl] If you looked at the brake cables, my teacher must have 4 cables, but unfortunately there may be a problem in the 307s before 2005, the engine cannot support the ECU. [/ QUOTE]
Brake sensor comes with 4 wires. We opened it in Ecu, we opened it.
08.05.2020 21:26 # 7
talip206
If the ECU has previously failed, the output may have been replaced by the part. So it may be giving this warning.
