A very interesting problem, please help
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 3008 (2009-2015)
08.05.2020 18:51 # 1
Utkucoskunn
First of all, good evening friends, I have a very interesting problem. My car is the 2014 model 3008 allure. When I put the air conditioner on the windshield to remove misting in my car, the car does not matter whether it is driving or stationary, a whistling sound comes from the car. When I checked to see where the sound came from, I realized that the sound came from the suppositories. When I deliver the warm air to the windscreen, air is circulating inside the wicks and making noise. When I press the suppositories, I can easily understand that there is air in it. When the air conditioner turns on normally, there is no problem only when I give it to the windshield. Please help me
08.05.2020 18:51 # 2
Dewil1606
Your vehicle is guaranteed, nothing else I can do other than to show it to the service
08.05.2020 18:51 # 3
Utkucoskunn
Thanks, how should I proceed? Because this is not the only problem of the vehicle. 1) dripping water from the driver's door when it rains 2) giving an airbag or safety belt error 3) whirring from the engine while the vehicle slows down 4) coming from the plastic parts of the gear to the ratchet 5) When the vehicle enters the pits, it sounds as if there are no shock absorbers. These are the main problems of the vehicle and the vehicle is still at 9000 km. All my trust in the brand was shaken after these events. When I go to the service, I do not want these problems to be corrected, or I did not know how to go a different way. Please help, what would you do
08.05.2020 18:51 # 4
tongucuk
only a simple guess might be that a dry leaf has entered from the outside, or a little boy may have thrown the item between the grills if you don't realize it.
08.05.2020 18:51 # 5
pusutr
I think you should take it directly to the service. Do not be tampered with. They will handle it.
