A strange mistake ???
08.05.2020 14:14 # 1
Hello;
I became a new member of the forum. I own a Peugeot 207. In case of a "beep" warning, I got the following error every 10 minutes:
"foolgump fault"
After the first warning, I pulled the ignition off and started it again. After 10 minutes, this warning came out a second time. The "beep" shape of the alert is the same as "fuel too low" ...
I did not search the internet .. I am looking at the meaning is very meaningless ...
I would be glad if someone who knows what these friends helps. Thanks...
08.05.2020 14:14 # 2
kamilgulcan
Could there be a fuel pump fault on the screen? if so, there may be debris in the fuel tank or an electrical fault ... the kamilgulc 2010-05-02 22:46:54
08.05.2020 14:14 # 3
Could it be :) Could I have seen this wrong? Of course I can be the road ... Gas pump ??? What is this?
08.05.2020 14:14 # 4
kamilgulcan
Did you feel any problems in the traction of your vehicle? Since the fuel pump is inside the tank, dirt and debris can affect the pump ... try to use the vehicle by filling the fuel in half a tank or over for a while. if it fails to give error, there is a break in the tank 90%, if it does not, it is likely that there will be an electrical error. It is useful to have the vehicle checked by connecting it to a computer. the kamilgulc 2010-05-02 22:52:22
08.05.2020 14:14 # 5
BuRCaK
If there is a service nearby, go to a computer and connect it. This is not a guesswork. These are sensitive issues. Do not be surprised by the service in such things, even if there is a fairing paint or something.
fuel too low: fuel means low. What was the fuel level in the vehicle? I wonder if he pulled my asshole?
08.05.2020 14:14 # 6
I pulled out the gas and set off on the 80th km of the road, I did it.
08.05.2020 14:14 # 7
kamilgulcan
it is largely due to gasoline, but it is still useful to connect it to the computer ...
08.05.2020 14:14 # 8
The other day he gave the same error again. This time, I noticed another .. It turns out that "foglamp faulity" was written. I think Foglamp means fog lamp. There is no fog lamp in my car either. What are you guys helping me? Teşekürler ...
08.05.2020 14:14 # 9
H-a-d-i
Could there be a rear fog lamp?
08.05.2020 14:14 # 10
I don't understand, it's gone ...
08.05.2020 14:14 # 11
IsmailAtes
It gives this error when any of your car's lighting bulbs have exploded.
