A question about the 307
08.05.2020 19:39 # 1
Hagen
(It is not an issue related to the other location, I am asking for something else entirely, I do not flood)
Hello friends;
The other day, the battery of my 307 vehicle ran out and I removed the battery terminals, took the battery from there, charged it nicely and put it back. and the vehicle is completely RESET. Brain or something
It was said that the vehicle will go to the authorized service and the software will be thrown.
How much will this incident cost me?
08.05.2020 19:39 # 2
ibrahim01
to the best of my knowledge, the battery is not reset while the battery is changing. Current information (such as date and time) on the information screen is reset. you need to use your own radio to fix them
08.05.2020 19:39 # 3
usta307
What does the vehicle do not say when my brother is reset?
08.05.2020 19:39 # 4
Hagen
Authorized service: The vehicle will be restarted with a complete reset.
08.05.2020 19:39 # 5
ibrahim01
so why did you go to the service? If you tell in detail, we can show a way. By the way, I think the car is walking since he went to the service ..
08.05.2020 19:39 # 6
Hagen
The vehicle does not move, I brought it to the vehicle with a taxi, and the laptop was connected to the vehicle with the Peugeot Planet 2000. Chassis number, Key etc. he forgot everything. and says "ECONOMY MODE ACTIVE", it is said to protect itself, the starter dynamo turns around, everything works, but neither the doors are locked nor the windows come down.
It was said that there was no malfunction in the vehicle but "RETURNED SOFTWARE IS DEALED WITH FRANCE".
how much money does this cost me?
08.05.2020 19:39 # 7
ibrahim01
this situation surpasses me. I also replaced the battery, but only the indicators have been reset.
08.05.2020 19:39 # 8
Hagen
Well, Ibrahim, thank you very much for your interest and interest.
Can anyone reply if anyone knows. ?
08.05.2020 19:39 # 9
talip206
Sir, I do not know if it helps, but if you write google a bsi reset and you have english, there is something. If you want to investigate a bit. For example;
http://rps-mobile-car-mechanic.co.uk/peugeot-citroen-bsi-reset/
08.05.2020 19:39 # 10
Hagen
No more places to look at.
There is no master in the industry.
I paid 30 lira and 50 lira for each person. They did not.
They said that it is necessary to take my vehicle to Edirne / Merkez with Kırklareli / Burgas. It was the most authoritative service.
Now they want me to pick up the car from the front of the house with the tractor and take it to burgaz.
+ Software
+ Key Coding
+ Set up BSI
+ Trinkets
How much does it demand from me? Someone who understands please write.
I hadn't removed the battery in my hand. I wish I would call someone and transfer, Damn the battery.
08.05.2020 19:39 # 11
burakrak53
I heard something like this for the first time, I hope I will say that it will not cost much, and has already gone here and there. When it dissolved, I was curious to inform us.
08.05.2020 19:39 # 12
xmen
Sir, I do not think it will be related to the battery, but whenever the battery changes, there should be such a problem.
08.05.2020 19:39 # 13
KIZILASLAN
the same thing happened to me, we had to remove the battery so we had to connect it to the reinforcement device so that the tape would not reset the settings in the service, the battery voltage had dropped in that secret, and the car bsi wiped its brain because the car was not working because they connected it to the planet 2000 device, so it didn't have anything to do with the software. bsi brain configuration has been reset, they will reload it, it has nothing to do with french or something, wasted money is not even the most bloodless private service for this process, it will not take more than 100 lira because it is a process that takes 15-20 minutes.
Get well soon
08.05.2020 19:39 # 14
Hagen
[QUOTE = KIZILASLAN] the same thing happened to me, we had to remove the battery, we had to connect it to the reinforcement device so that the tape's settings would not be reset in the service. There is nothing to do, only the configuration of the bsi brain has been reset, they will reload it. It has nothing to do with French and nothing.
Get well soon
Thanks a lot for your comment
but they opened that program in me.
But they couldn't install it, just like you said, the immo light is flashing fast.
Napacam I do not know, I do not move, if I take it to the service, it will not be less than 1.5, now this will tell me that all of the services will say opportunistic brain, what will I change, etc.
It is very hard to get up from the bidet and carry the vehicle with 150KM Cekici.
I asked if they were getting 5 lira per KM.
Did you also say "ECONOMY MODE AVTIVE"? I'm starting an engine, I'm not going to be crazy.
08.05.2020 19:39 # 15
KIZILASLAN
brother, your trouble is actually very simple, the person you brought does not know how to use the planet 2000 program. 85 84 the victorious master man's name is a bit of a stingy man, but a specialist man in pejos will do your job if you want to get out of the authorized service if you want to convince him.
08.05.2020 19:39 # 16
KIZILASLAN
I came to my mind recently, a friend of mine had been in your vehicle like yours, the battery was finished by pushing the room, he tried to run the bsi, he wiped the brain, we called the victor master, the man went to the vehicle new battery + reprogramming received 400 TL for all of them.
08.05.2020 19:39 # 17
Hagen
Can you send a private message to KIZILASLAN, your phone number, my friend
08.05.2020 19:39 # 18
dgngogo
if you asked my friend to get past or ask how much money you want to service .......... you keep jumping here how much money here how much money
dgngogo 2016-02-12 23:03:09
08.05.2020 19:39 # 19
KIZILASLAN
[QUOTE = dgngogo] get past if you ask my friend or how much money do you want to service .......... you keep jumping here how much money how much money
What service vehicle will give you the price, if you read above, the man who wrote it is not working in the vehicle because the service is 150 km away ...
08.05.2020 19:39 # 20
dgngogo
Well, how do you give prices without seeing it? Everyone tells something, confused ice confused, how many money do you think? do not look.
Page : / 2
