A question about 106 quik
08.05.2020 16:28 # 1
kaderim@61
I am calling out to friends who have 106 quiks from here. If there is any oxygen sensor among you, I would appreciate it if you inform what changes have happened in the vehicle. Good evening
08.05.2020 16:28 # 2
AhMeT®
I have qs. But I haven't changed it, I think it will change too. I heard you notice it in the fuel and shots.
08.05.2020 16:28 # 3
yavuz25
Is it something that changes according to km or it changes like my normal part?
08.05.2020 16:28 # 4
by_imp
As far as I know, it has become a chronic problem of 106s, something that changes when it breaks down.
08.05.2020 16:28 # 5
yavuz25
[QUOTE = AhMeT®] I have qs. But I haven't changed it, I think it will change mine. I heard it noticeable in fuel and shots, but my brother has a fault lamp. /smileys/smiley2.gif "height =" 17 "width =" 17 "border =" 0 "alt =" Wink "title =" Wink "/>
08.05.2020 16:28 # 6
AhMeT®
As far as I know if the oxygen sensor malfunctions, the malfunction lamp is yakiyo. I came from the repair shop a little while ago, the oxygen sensor was wrong with me. The pc also came out. When the oxygen sensor malfunctioned, the car experienced a lot of loss and performance, so my mechanic said that. the most recent change of sensors and sensor.
08.05.2020 16:28 # 7
kaderim@61
The life of this sensor was km limited, 120 thousand, 100 thousand, it was such a master, I forgot, when I forgot, there were noticeable changes, when I thought about the fuel in the traction, I thought I had noticed these if there was a change of fabrica on the logical vehicle. When it shifts to second gear, I asked him as if someone hit you, they said it was
08.05.2020 16:28 # 8
AhMeT®
Well, brother, I fix my hand, I will renew it from the heat sensor to the oxygen sensor. We see the benefit of all gasoline :-) The first name will be to learn the prices of the sensors.
08.05.2020 16:28 # 9
kaderim@61
There are two sensors, one is attached to the manifold, the other is the price attached to the manifold, which should change to the catalyst 150 lira original bosh bosh when it first invented this sensor
08.05.2020 16:28 # 10
AhMeT®
My heat sensor and fan sensor will change. Plus the oxygen sensor is needed. We will have to compensate that money. No care to do biniosis
08.05.2020 16:28 # 11
kaderim@61
I will change to the spring, I have a few things to do steering wheel reverberation discs and so on
08.05.2020 16:28 # 12
AhMeT®
I spent more than 700__800 until it was a month since I bought the car. want a bad temper
08.05.2020 16:28 # 13
ozdemirosman
I don't even know about a piece like that
