A problem with the gearbox!
08.05.2020 16:17 # 1
Friendchip
Hello everyone,
I started to get bored with a voice that I thought came from the gearbox of my vehicle (2006 model 307 HDI Premium 110 HP) I bought about 10 months ago. This is a sound that is intermittent, like the rubbing sound I hear while driving, and is increasing in direct proportion with acceleration. I showed it to the master and listened to the sound, as if it came from the gearbox, but let's not open it, he said. After using it for a while, both the sound of the car and the sound inside me continue to bother me. I request the comments of my friends who have experience in this field and of course the expert members on the subject.
I wish you all an accident-free and trouble-free, pleasant trip .. & nbsp; Reviews
08.05.2020 16:17 # 2
Do you feel a vibration on your foot when you lightly press the clutch pedal?
08.05.2020 16:17 # 3
Friendchip
Yes I was feeling, & nbsp; however, the clutch set changed about a month ago. & nbsp; The problem I mentioned was not improved. This sound can be heard easily in use.
08.05.2020 16:17 # 4
[QUOTE = Friendchip] I was feeling yes, & nbsp; however, the clutch set changed about a month ago. & nbsp; The problem I mentioned was not improved. This sound can be heard easily in use. [/ QUOTE]
Was there any sound before changing clutch set?
08.05.2020 16:17 # 5
Friendchip
Yes there was. In other words, the change of clutch set was not effective in reducing the volume even in this way & nbsp;.
08.05.2020 16:17 # 6
[QUOTE = Friendchip] Yes, there was. In other words, the change of the clutch set was not effective in reducing the volume of this sound in any way. [/ QUOTE]
I think the problem is English release bearing, thrust bearing, throw-out bearing (all the same) but the sound You need to listen well. This piece does not come with a clutch set, but the changed master should have been able to understand it with ease. This is another issue. If you can shoot a video, maybe we can make more accurate comments.
koliva 2011-10-24 14:34:16
08.05.2020 16:17 # 7
Friendchip
I will try to shoot and publish her video soon. I'll send you a PM. Thank you for your attention, Koliva.
08.05.2020 16:17 # 8
Friendchip
Hello Again,
I failed to add the video to the site but I am giving the link.
& nbsp;
08.05.2020 16:17 # 9
Obviously I couldn't hear a voice. Is this sound when the vehicle is stationary? Or is there any sound when you press the clutch while it is still standing?
08.05.2020 16:17 # 10
Friendchip
I think the real mistake comes from listening to the sound of the motor, I & nbsp; I have experienced it like you .. The sound that is heard is actually like the sound of the two boards or plastics rubbing together in the interval of 2000-3000 cycles. In this case there is no sound. It can only be heard at speeds of 20-30 km / h and 50-70 km / h between 2000-3000 revolutions while driving. Engine sound may be inaudible at higher revs as it suppresses this sound. I think it's not about clutch, because nothing related has happened.
& nbsp;
In the early days, I had never heard of it, my attention was always at another point, but lately I've always listened to it. I am driving about 20000 km, I think my car was always there, but I am aware that it is 15000 km ..
I'm afraid it's all about the gearbox and it will cost me a lot. If I can detect the problem at the very beginning, the solution will be less expensive. Therefore, I am meticulous.
I think I will show it to the service once. There was a campaign in Peugeot, as 100 TL fuel gift for 4 michelin tires. I plan to focus on this issue when I change the tires. I will write the situation for you ..
& nbsp;
Greetings.
08.05.2020 16:17 # 11
There is a sound like springing sound coming in the 8th second. Do you mean it & nbsp; "Ouch"
08.05.2020 16:17 # 12
Friendchip
No, unfortunately, I don't want to mean it. How would I describe it! Like filing sound, action sound .. It starts at the 5th second, the sound is heard as the speed increases. "C
08.05.2020 16:17 # 13
Friendchip
http://www.youtube.com/watch?v=PAJoC_ltbcQ
http://www.youtube.com/ watch? v = qi_H6A3lbkg
& nbsp;
http://www.youtube.com/watch?v=2J8R69UX2og
http://www.youtube.com/watch? v = Nmms-ElZ6Fs
These may also give some idea ..
08.05.2020 16:17 # 14
okankrgz
I guess you have a problem in the mirror mahir .... the sound increases as you press the gas, and there is no sound when you shift the gear into neutral.
There must be a buzzing sound, this is a sound that increases as I load it ... & nbsp; I have this in the 4th and 5th gears, but this mirror is caused by life.
Do you have a problem afterwards or do you have your car since you bought it? Do not lower your gearbox, if there is a problem with the gears, you will get this sound in every revolution, do not lower the transmission in vain ... To remove this sound, remove the mirror and make it look nice. I think, if you can hear the sound comfortably, I think the trouble is in the mirror mahrutide)
08.05.2020 16:17 # 15
sedatdatse
I have the same problem in my vehicle, the socket drek felt my ball so they said it was inside the press pad set
08.05.2020 16:17 # 16
Friendchip
Friends, I had the Peugeot Arkas serviced in Izmir. During the test drive, it was determined that the sound comes directly from the transmission & nbsp; bearing probability problem. However, it was said that the gearbox should definitely be opened for a more detailed expertise. At this stage, they said that I would not go on like this, we would have to lower the gearbox if the sound increased. The minimum cost would be 700-800 TL.
Thanks to other friends for their comments ..
08.05.2020 16:17 # 17
hcbank
offf offf you get tired of these transmission problems now god help me my friend
note: in gearbox
