A place that can introduce cruise control to 206 in Istanbul
08.05.2020 18:37 # 1
sicey
Hello friends,
I bought my 2004 model 206 hdi 4-wire brake master vehicle with cc. Tactics
In Umramiye industry, a place that meets the brain name is over pp2000
He did a lot, but he couldn't. I got some information from our friend Serkan, I will have him checked tomorrow, but I don't think he will be there anybody knows where I can get this introductory work done in Istanbul?
08.05.2020 18:37 # 2
Serkan
We did not hear of 206 wearers in the forum other than us in Istanbul, I gave you the necessary information and there is no other formula.
08.05.2020 18:37 # 3
sicey
I have reviewed the forums quite a bit other than you
I am aware that you are not
I said ask a question. I will try the information you provided tomorrow, one last question serkan :) in the photos you sent 2. There is no cruise control in the photo
You marked the place where you wrote the red and we will not do as in the photo
Or should it be made available there?
08.05.2020 18:37 # 4
Serkan
Yes Sir, you will make the place that says No, there is speed stabilization on the other hand, you will choose the one without limitation, menus may show minor changes, for example, speed regulator instead of speed stabilization, speed limiter instead of limitation, then there is speed regulator, you choose the author who does not have speed limiter, As I said, when connecting the vehicle, select 207 and after doing these two encodings, start and stop the vehicle once and wait until bsi goes to sleep, then go out and test it, you will not see any warning on the screen, the 4th gear after 60 km speed, the cc lever `` Turn it to the `` on '' position and press the `` - '' or `` + '' buttons at the bottom, though it works in 3 gears in 206, but you get the guarantee of 4.
08.05.2020 18:37 # 5
okaNStarss
How much did you get the arm? I want to do it too.
08.05.2020 18:37 # 6
sicey
I write from private, where I bought it
Do not get infected before finding it, we have been practicing in the brain since
No, I gave up today, I can find a master who can do it :)
08.05.2020 18:37 # 7
okaNStarss
[QUOTE = sicey] I write from Private, where I bought it
No, I gave up today, I can find a master who can do it:) [/ QUOTE]
serkan friend gave me the name of the place that can make adanda my car 2006 model has made many friends in the forum before, it is not a problem since I do not think it will be a problem :)
08.05.2020 18:37 # 8
sicey
I hope someone who has done it before
If you do, I don't think you will leave, if you make me inform
You'd better know how :)
08.05.2020 18:37 # 9
Alicilik
207 + partner combination teacher. The only thing you need to pay attention to is pp2000. There is no connection from v24 and after 207.
What to do in 206 will be if you do it in 207 and in the partner. I have done many vehicles.
08.05.2020 18:37 # 10
sicey
[QUOTE = Buying] 207 + partner combination teacher. The only thing you need to pay attention to is pp2000. There is no connection from v24 and after 207.
Exactly, maybe it is from her, 207 from the brain and cruise control
We chose the disappearing place, but we chose 207 to enter bsi
The device did not allow us to have 1 speed regulator which we selected from 206
As there is no speed limit, maybe as you said, from the version
Pejo could not be from 207
Where do you live, teacher?
08.05.2020 18:37 # 11
Alicilik
I'm in Ankara, but your priority is to find planetary software below v24.
08.05.2020 18:37 # 12
silenos
friends, I am thinking of taking the arm to 307, but my vehicle will be incompatible with the 2003 model.
08.05.2020 18:37 # 13
Alicilik
[QUOTE = silenos] friends, I am thinking of getting 307 arm but my vehicle is 2003 model incompatibility I wonder if anyone knows [/ QUOTE]
I'll try to help if you share the chassis number from the private but your brake sender scares me Sleepy
08.05.2020 18:37 # 14
Ayhan82
I want to get it
08.05.2020 18:37 # 15
[QUOTE = Ayhan82] I want to have it [/ QUOTE]
How many coaches and brake sensors do your model of vehicle come with?
