A new fault does not work with gas
08.05.2020 19:22 # 1
blntctn
Hello friends again
The car left the headlights on and off 3 months ago, the friend had run out of the battery, we ran the car, it did not cause any problems after the car, but the other day, I entrusted it to another friend, said that the car did not work when I called the car again, I asked him that the light was over and over again, he said he did not remember, but everything was normal, the headlights were not burning, whatever the car worked. I returned and returned the vehicle, but when I first started the car, the battery does not work like it is dead.
08.05.2020 19:22 # 2
Electronic systems can be damaged due to high voltage caused by a dangerous operation. It may be caused by the starter motive, but first go to an electrician and have it measured and checked.
08.05.2020 19:22 # 3
blntctn
We found the problem in the vehicle, they said that one of the plates in the battery was broken and the new battery would fix the problem.
08.05.2020 19:22 # 4
I'm glad your problem is solved. Hope you use it without any trouble and trouble.
