A little question
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 208
23.06.2020 23:00 # 1
cnrbrk
Good evening friends, I joined you as a new owner of Peugeot 208, I have a few urgent questions.I am waiting with your questions.If you explain, we brought your answers to the park first, we put the car on the park, then we turned off the ignition, but when we do not turn off the ignition, I was curious about the reason for this. Another curiosity is also priority. As we park the car, it would be the healthiest position to leave the gear in which position, and I would be glad if you inform me what I need to pay attention to in use because the gear is a robotic gearbox, my car is 208 2015 model 1.2 egt5
24.06.2020 15:07 # 2
First of all, welcome to us. If you open the door when you do not remove the key from the ignition, it is a normal situation for security purposes. If you put the hand brake in neutral and pull the handbrake while parking, the load of the vehicle will not be on the transmission, this is the healthiest thing. Put it to neutral and pull the elfren, take your foot off the brake pedal, and after the load gets on the brakes, take it to the park position.
25.06.2020 11:59 # 3
cnrbrk
Professor, give me my ignorance again what happens in the parking position gear lever RNA hamgi
25.06.2020 12:26 # 4
(R) back (N) blank (A) forward teacher. You can find vehicle shops here. http://public.servicebox.peugeot.com/APddb/#topsonerkyl2020-06-25 12:26:46
